Background
Ubuntu 8.04 server 64bit edition
PCI-e DVR card with 8 chips - based on phillips SAA7130 chipset
this is the card I have:
http://www.camsecure.co.uk/PCIECapture.html
According to HCL the drivers for the card are installed:
video 0 to 7 are listed in the /dev directory
zmu output:
I currently can't get an image from either zoneminder or xawtvroot@fileserver:~# zmu -d /dev/video0 -q -v
Video Capabilities
Type: 45
Can capture
Does teletext
Overlay onto frame buffer
Can clip
Video Channels: 1
Audio Channels: 0
Maximum Width: 720
Maximum Height: 578
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 0
Height: 0
Picture Attributes
Palette: 4 - 24bit RGB
Colour Depth: 24
Brightness: 46774
Hue: 32896
Colour :33026
Contrast: 35090
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 0
Type: 2 - Camera
Format: 0 - PAL
output from xawtvis:
I have read that there is a bttv.conf or an modprobe.conf file that probably needs modifying but I can't find either!root@fileserver:~# xawtv
This is xawtv-3.95.dfsg.1, running on Linux/x86_64 (2.6.24-24-server)
xinerama 0: 1024x768+0+0
Warning: Cannot convert string "-*-ledfixed-medium-r-*--39-*-*-*-c-*-*-*" to type FontStruct
game over
Some help would be really appreciated!
