Hi
I'm having problem installing the chip: 878A
Such a card like this:
http://cgi.ebay.com/8-Channel-Real-time ... 286.c0.m14
Zoneminder installed with. RPMs
http://liquid-co.de/pub/suse/repositori ... x86_64.rpm
information: OpenSUSE 11.1 / Intel Core 2 Quad / 4GB RAM / GA-G31M-ES2L
Zoneminder starts and after entering the address of the program operates, but does not display the image.
In / var / log / messages
Sep 21 10:40:50 local zmdc[4175]: INF [Starting pending process, zmc -d /dev/video4]
Sep 21 10:40:50 local zmdc[4175]: INF ['zmc -d /dev/video4' starting at 09/09/21 10:40:50, pid = 16844]
Sep 21 10:40:50 local zmdc[16844]: INF ['zmc -d /dev/video4' started at 09/09/21 10:40:50]
Sep 21 10:40:50 local zmc_dvideo4[16844]: INF [Debug Level = 0, Debug Log = <none>]
Sep 21 10:40:50 local zmc_dvideo4[16844]: INF [Starting Capture]
Sep 21 10:40:50 local zmc_dvideo4[16844]: ERR [Capture failure for frame 0: Device or resource busy]
Sep 21 10:40:50 local zmc_dvideo4[16844]: ERR [Failed to prime capture of initial monitor]
Sep 21 10:40:50 local zmdc[4175]: ERR ['zmc -d /dev/video4' exited abnormally, exit status 255]
Sep 21 10:45:01 local zmdc[4175]: INF [Command 'zmc -d /dev/video4' removed from pending list at 09/09/21 10:45:01]
Sep 21 10:45:01 local zmdc[4175]: INF ['zmc -d /dev/video4' starting at 09/09/21 10:45:01, pid = 17415]
Sep 21 10:45:01 local zmdc[17415]: INF ['zmc -d /dev/video4' started at 09/09/21 10:45:01]
Sep 21 10:45:01 local zmc_dvideo4[17415]: INF [Debug Level = 0, Debug Log = <none>]
Sep 21 10:45:01 local zmc_dvideo4[17415]: INF [Starting Capture]
Sep 21 10:45:01 local zmc_dvideo4[17415]: ERR [Capture failure for frame 0: Device or resource busy]
Sep 21 10:45:01 local zmc_dvideo4[17415]: ERR [Failed to prime capture of initial monitor]
/etc/modprobe.d/tv
alias char-major-81 videodev
options i2c-algo-bit bit_test=1
options bttv tuner=-1,-1,-1,-1,-1,-1,-1,-1
# YaST configured TV card
# 9ftC.bJ31E5obFa9:Bt878
alias char-major-81-0 bttv
# Emwg.bJ31E5obFa9:Bt878
alias char-major-81-1 bttv
# Jtz8.bJ31E5obFa9:Bt878
alias char-major-81-2 bttv
# O_0d.bJ31E5obFa9:Bt878
alias char-major-81-3 bttv
# T545.bJ31E5obFa9:Bt878
alias char-major-81-4 bttv
# YC7Z.bJ31E5obFa9:Bt878
alias char-major-81-5 bttv
# dJA1.bJ31E5obFa9:Bt878
alias char-major-81-6 bttv
# hQDV.bJ31E5obFa9:Bt878
alias char-major-81-7 bttv
------ Shared Memory Segments --------
key shmid owner perms bytes nattch status
0x00000000 196608 root 600 67108864 9 dest
0x7a6d0001 65537 wwwrun 700 9217524 1
shmmax
18446744073709551615
shmall
1152921504606846720
Name: BT878 video ( *** UNKNOWN/GENER
Type: 47
Can capture
Can tune
Does teletext
Overlay onto frame buffer
Can clip
Video Channels: 4
Audio Channels: 0
Maximum Width: 924
Maximum Height: 576
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 240
Picture Attributes
Palette: 4 - 24bit RGB
Colour Depth: 24
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 1
Channel has a tuner
Type: 1 - TV
Format: 0 - PAL
Channel 1 Attributes
Channel: 1
Flags: 0
Type: 2 - Camera
Format: 0 - PAL
Channel 2 Attributes
Channel: 2
Flags: 0
Type: 2 - Camera
Format: 0 - PAL
Channel 3 Attributes
Channel: 3
Flags: 0
Type: 2 - Camera
Format: 0 - PAL
Video Capabilities
Monitor in ZoneMinder
#### GENERAL
Source Type: Local
Fuction: Monitor
Enabled: Yes
Linked Monitors: none
Maximum FTS: 25.00
Alarm Maximum FPS: 25.00
Reference Image Blend %ge: 7
Triggers: None
#### SOURCE
Device Path: /dev/video4
Capture Method: Video For Linux version 1
Device Channel: 0
Device Format: PAL
Capture Palette: RGB24
Capture Width (pixels): 320
Capture Hight (pixels): 240
Preserve Aspect Ratio: none
Orientation: Normal
#### TIMESTAMP
Timestamp Label Format: %N - %y/%m/%d %H:%M:%S
Timestamp Label X: 0
Timestamp Label Y: 0
#### BUFFERS
Image Buffer Size (frames): 40
Warmup Frames: 25
Per Event Image Count: 10
Post Event Image Count: 10
Stream Replay Image Buffer: 1000
Alarm Frame Count: 1
#### Misc
Event Prefix: Event-
Section length: 600
Frame Skip: 0
FPS Report Interval: 1000
Default View: Events
Default Rate: Real
Default Scale: Actual
Signal Check Colour: #0100BE
Web Colour: red
Anyone have an idea what could be the problem?
Thanks for any suggestions
OpenSUSE 11.1 chip 878A don't display video
only run on MoTV or kdetv
The camera can run under KDE in the "MoTV" or "kdetv" but only if the camera is plugged into port 1 on the other 7 ports, no picture.
In zoneminder on each channel no video.
Pls .. help me:) I have no ideas
Yes, I checked viteo0,video1.....video7
Yes, I checked video0,video1.....video7 Device Path in ZoneMinder settings monitor and does not work, the logs do not change, are still the same for /dev/video0..../dev/video7
Thanks for interest that topic.
ok try running
see what is there video0-etc
next did you set the shared memory see faq
last are all configured cameras capturing the same size and color mode.
sudo ls /dev
file in /dev
File in /dev
FAQ? you mean documentation zonminder?
http://www.zoneminder.com/wiki/index.ph ... umentation
if yes, I can not find a point of information about setting up share memory
if it is not a problem, please give the point to which this information relates
I have only one camera at the moment now.
Camera Settings:
#### GENERAL
Source Type: Local
Fuction: Monitor
Enabled: Yes
Maximum FTS: 25.00
Triggers: None
#### SOURCE
Device Channel: 0
Device Format: PAL
Orientation: Normal
video video0 video1 video2 video3 video4 video5 video6 video7 - OK.udev XOR Adsp Agpgart Audio Blog Bootsplash Bsg Bus Cdrom Cdrw Console Core Cpu cpu_dma_latency device-mapper disk dri dsp dvd dvdrw fb fb0 fd fd0 fd0u1040 fd0u1120 fd0u1440 fd0u1600 fd0u1680 fd0u1722 fd0u1743 fd0u1760 fd0u1840 fd0u1920 fd0u360 fd0u720
fd0u800 fd0u820 fd0u830 full fuse fwmonitor hpet initctl input kmem kmsg log loop0 loop1 loop2 loop3 loop4 loop5 loop6 loop7 lp0 mapper mcelog md0 md1 md10 md11 md12 md13 md14 md15 md16 md17 md18 md19 md2
md20 md21 md22 md23 md24 md25 md26 md27 md28 md29 md3 md30 md31 md4 md5 md6 md7 md8 md9 mem mixer net network_latency network_throughput null nvram oldmem parport0 perfmonctl port ppp psaux ptmx pts random root
Route Rtc rtc0 scd0 sda sda1 sda2 sda3 sda4 sda5 sda6 sda7 sg0 sg1 shm skip snapshot snd sr0 stderr stdin stdout tty tty0 tty1 tty10 tty11 tty12 tty13 tty14 tty15 tty16 tty17 tty18 tty19 tty2
tty20 tty21 tty22 tty23 tty24 tty25 tty26 tty27 tty28 tty29 tty3 tty30 tty31 tty32 tty33 tty34 tty35 tty36 tty37 tty38 tty39 tty4 tty40 tty41 tty42 tty43 tty44 tty45 tty46 tty47 tty48 tty49 tty5 tty50 tty51 tty52
tty53 tty54 tty55 tty56 tty57 tty58 tty59 tty6 tty60 tty61 tty62 tty63 tty7 tty8 tty9 ttyS0 ttyS1 ttyS2 ttyS3 ttyS4 ttyS5 ttyS6 ttyS7 urandomusbdev1.1_ep00 usbdev1.1_ep81 usbdev2.1_ep00
usbdev2.1_ep81 usbdev3.1_ep00 usbdev3.1_ep81 usbdev4.1_ep00 usbdev4.1_ep81 usbdev5.1_ep00 usbdev5.1_ep81 v4l vbi
vbi0 vbi1 vbi2 vbi3 vbi4 vbi5 vbi6 vbi7 vcs vcs1 vcs10 vcs2 vcs3 vcs4 vcs5 vcs6 vcs7 vcsa vcsa1 vcsa10 vcsa2 vcsa3 vcsa4 vcsa5 vcsa6 vcsa7 video video0 video1 video2 video3 video4 video5 video6 video7 watchdog xconsole zero
Camera Settings:
#### GENERAL
Source Type: Local
Fuction: Monitor
Enabled: Yes
Maximum FTS: 25.00
Triggers: None
#### SOURCE
Device Channel: 0
Device Format: PAL
Orientation: Normal
Success! Almost 100%
I uinstall zoneminder v1.24.1 and v1.23.3 installed.
The image is ok, and zero errors in the logs, so can consider that everything is working properly.
This is not a perfect solution because I use older version of the software zoneminder.
Perhaps the author of the program will improve the error in the next version, as I waited to use the software fresh.
Thanks for the help and interest this topic of Mr.
kingofkya
PS: If anyone has any ideas for running ZM v1.24.1 to invite you to entry in this post.
