Page 1 of 1
can't get any camera's up
Posted: Mon Sep 21, 2009 7:38 pm
by Pr0n
no matter what I try any camera I add to a monitor is 'idle' 0fps and black. I have tried everything I have tried readnig through the wiki and can't find anything that will help me. I have 4 generic camera's that are /dev/video0 /dev/video1 and so on.
the system is on ubuntu JJ
also is there a precompiled 1.24 I tried compiling it on my own but I've never done this much with linux before this is a learning process for me.
below are some logs the filter and audit logs are either empty or negligable
here's what I get runing the zmu command on a camera
$ sudo zmu -d /dev/video0 -q -v -U admin -P admin
Video Capabilities
Name: BT878 video ( *** UNKNOWN/GENER
Type: 47
Can capture
Can tune
Does teletext
Overlay onto frame buffer
Can clip
Video Channels: 4
Audio Channels: 0
Maximum Width: 924
Maximum Height: 576
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 240
Picture Attributes
Palette: 4 - 24bit RGB
Colour Depth: 24
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 1
Channel has a tuner
Type: 1 - TV
Format: 0 - PAL
Channel 1 Attributes
Channel: 1
Flags: 0
Type: 2 - Camera
Format: 0 - PAL
Channel 2 Attributes
Channel: 2
Flags: 0
Type: 2 - Camera
Format: 0 - PAL
Channel 3 Attributes
Channel: 3
Flags: 0
Type: 2 - Camera
Format: 0 - PAL
this is the end of the zmdc log
09/21/09 13:31:13.752493 zmdc[2697].INF ['zmc -d /dev/Video0' starting at 09/09/21 13:31:13, pid = 2996]
09/21/09 13:31:23.983307 zmdc[2697].INF ['zmc -d /dev/Video0' stopping at 09/09/21 13:31:23]
09/21/09 13:31:34.236499 zmdc[2697].INF [Can't find child with pid of '3026']
09/21/09 13:31:34.237133 zmdc[2697].INF ['zmc -d /dev/Video0' starting at 09/09/21 13:31:34, pid = 3026]
09/21/09 13:31:44.785405 zmdc[2697].INF ['zmc -d /dev/Video0' stopping at 09/09/21 13:31:44]
09/21/09 13:31:55.021707 zmdc[2697].INF [Can't find child with pid of '3029']
09/21/09 13:31:55.022216 zmdc[2697].INF ['zmc -d /dev/Video0' starting at 09/09/21 13:31:55, pid = 3029]
09/21/09 13:32:05.224293 zmdc[2697].INF ['zmc -d /dev/Video0' stopping at 09/09/21 13:32:05]
09/21/09 13:32:15.455901 zmdc[2697].INF [Can't find child with pid of '3033']
09/21/09 13:32:15.456406 zmdc[2697].INF ['zmc -d /dev/Video0' starting at 09/09/21 13:32:15, pid = 3033]
09/21/09 13:32:25.650364 zmdc[2697].INF ['zmc -d /dev/Video0' stopping at 09/09/21 13:32:25]
09/21/09 13:32:35.882737 zmdc[2697].INF [Can't find child with pid of '3066']
09/21/09 13:32:35.883428 zmdc[2697].INF ['zmc -d /dev/Video0' starting at 09/09/21 13:32:35, pid = 3066]
09/21/09 13:32:46.087803 zmdc[2697].INF ['zmc -d /dev/Video0' stopping at 09/09/21 13:32:46]
09/21/09 13:32:56.313125 zmdc[2697].ERR ['zmc -d /dev/Video0' exited abnormally, exit status 255]
09/21/09 13:32:56.313636 zmdc[2697].INF ['zmc -d /dev/Video0' starting at 09/09/21 13:32:56, pid = 3070]
watch.log is full of this
09/21/09 13:34:49.147240 zmwatch[2844].INF ['zmc -d /dev/Video0' stopping at 09/09/21 13:34:49]
09/21/09 13:34:59.148284 zmwatch[2844].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
09/21/09 13:34:59.148521 zmwatch[2844].INF [Restarting capture daemon for Front, shared memory not valid]
09/21/09 13:34:59.368526 zmwatch[2844].INF [Can't find child with pid of '3159'] at /usr/bin/zmwatch.pl line 119
Posted: Mon Sep 21, 2009 8:03 pm
by kingofkya
Read the FAQ regarding shared memory
Posted: Tue Sep 22, 2009 9:25 am
by cordel
You need to find out what video capture card you have and manually create a modprobe config file to set it up. It not correctly detected.
