I have these working on CentOS 5.
Upgrade to latest firmware. At this time it is 1.01. 1.0 Will not work right for some reason.
Firmware/Info PVC2300--> http://www.cisco.com/en/US/products/ps9945/index.html
Firmware/Info WVC2300-->http://www.cisco.com/en/US/products/ps9947/index.html
I got mine from Newegg.com
Make sure you get the proper firmware for the proper device. They have different .bins
I set up a user on the camera username zm and password zm.
When i set a monitor in zoneminder I used the following
Source=remote
Maximum FPS=30
Alarm Maximum FPS=30
Remote protocal=HTTP
Remote Method=Simple
Remote Host Name=zm:zm@{your ip addy of the camera}
Remote Host Port=80
Remote Host Path=/img/video.mjpeg
Remote Image Colours=24 bit
Capture Width=640 (Same as in camera setup)
Capture Height=480 (Same as in camera setup)
Everything else i left default. Now, i am still a newbie at zoneminder, so my FPS and such might be out of wack, but the cameras work in zoneminder great.
I will monitor this post, so reply if i can help in any way.
Good luck!!
mrme
Tags to make it easy to find via search.
Linksys ip camera, cisco ip camera, cisco small business
Cisco PVC2300 Cisco WVC2300
CISCO camera PV2300
Hi mrme
I just want to ask you a question, are your very happy to buy this camera PV2300, because I really want to get it also but I dont know if it's a good choice and also if it's compatible with Zoneminder, So could you give me more information because at the moment I want to get it and buy know but I prefer to ask you a question before thank you .
I want this camera because I work since 4 years with Asterisk and I want to try to connect Zoneminder with asterisk and openfire so for that I need to have a camera whit a microphone to get the sound , so do you think it's a good choice this camera for me thank you.
PS: sorry for my english I'm french and I don"t speak and write very weel englsih sorry (
Sorry it took so long to reply.
I love these cams. They are very clear. Zoneminder is a good script and well worth the time. They work great with zoneminder.
These cams to have jacks for audio input and output. I do not use the audio, but i have heard good things about it.
Dont worry about your English, i am from the deep south of USA, and yours is better that most people i deal with down here!!
Let me know if there is any other way i can help
Problem to see both of my camera Video with zoneminder
Thank a lot to answer my question , and sorry also because I'm also long to reply .
I just want to ask you again some question if you are agree ???
I'm professionnal of asterisk but not on the Zoneminder and I really want to try to connecte my asterisk and zoneminder but unfortunatly is't more hard as I was thinking
Todays my zoneminder is running but I cannot see any camera on the screen : I'll explain to you more and I hope you can help me little bit thank you.
I have 2 caméra WVC2300 and WVC210 and this camera work if I'm using the link http access direct by the server WEB inside on the camera so this is the link I use to see directly on the firefox
http://user:password@IP_Server/img/video.mjpeg this is for both of the camera WVC210 ans also WVC2300 and is working ok!
so that is normal for the moment ok and I prefer to configure my camera WVC2300 on RTSP protocol to using on zoneminder .
So I catch the signal video directly on VLC I only do that just to be sure the RTSP is working and It's ok I can see direct on VLC with the WVC2300 but the RTSP for the WVC210 it is not working because I didn't find the right path beacause is not the same as below
rtsp://192.168.1.100:554/img/video.MPEG-4%20SP this work on VLC for WVC2300 but not with WVC210.
OK let talk now onn my zoneminder problem
so this is the problem I put both of the camera on zoneminder and I can't see any flux video on the creen, I tried both of the config one with HTTP and the other one with RTSP and same problem no video???? Zoneminder writting running I can stop and start without problem so everything looks like correct but can not find the video flux on both camera
this is the configuration on my 2 camera
screen - WVC230 RTST
* General
Name WVC2300
Source Type remote
Fonction monitor
Activity yes stick
i/s maximum 30.00
Alarm Maximum FPS nothing
Reference Image Blend %ge 7
* Source
Remote Protocol RTSP
Remote Method RTP/RTSP
Remote Host Name 192.168.1.100
Remote Host Port 554
Remote Host Path img/video.MPEG-4%20SP
Remote Image Colours 24bit
Larg. capture (pixels) 320
Haut. capture (pixels) 240
Preserve Aspect Ratio no stick
screen - WVC210 HTTP
* General
Name WVC210
Source Type remote
Fonction monitor
Activity yes stick
i/s maximum 30.00
* Source
Remote Protocol HTTP
Remote Method SIMPLE
Remote Host Name 192.168.1.101
Remote Host Port 80
Remote Host Path img/video.mjpeg
Nom Fonction Source Evènts Heure Jour Semaine Mois Archived Zones Order Marque
0 0 0 0 0 0 1
WVC2300 Monitor 192.168.1.205 0 0 0 0 0 0 1 UpDown
WVC210 Monitor 192.168.1.204 0 0 0 0 0 0 0 UpDown
and Nothing work so if you can help me to explain me exactly where is my problem it'll be great thank you a lot
Cordialy
Diablo
* General
Name WVC2300
Source Type remote
Fonction monitor
Activity yes stick
i/s maximum 30.00
* Source
* General
Name WVC210
Source Type remote
Fonction monitor
Activity yes stick
i/s maximum 30.00
* Source
Remote Host Port 80
0 0 0 0 0 0 1
Cordialy
Diablo
