Cisco PVC2300 Cisco WVC2300
Posted: Mon Sep 21, 2009 9:06 pm
I have these working on CentOS 5.
Upgrade to latest firmware. At this time it is 1.01. 1.0 Will not work right for some reason.
Firmware/Info PVC2300--> http://www.cisco.com/en/US/products/ps9945/index.html
Firmware/Info WVC2300-->http://www.cisco.com/en/US/products/ps9947/index.html
I got mine from Newegg.com
Make sure you get the proper firmware for the proper device. They have different .bins
I set up a user on the camera username zm and password zm.
When i set a monitor in zoneminder I used the following
Source=remote
Maximum FPS=30
Alarm Maximum FPS=30
Remote protocal=HTTP
Remote Method=Simple
Remote Host Name=zm:zm@{your ip addy of the camera}
Remote Host Port=80
Remote Host Path=/img/video.mjpeg
Remote Image Colours=24 bit
Capture Width=640 (Same as in camera setup)
Capture Height=480 (Same as in camera setup)
Everything else i left default. Now, i am still a newbie at zoneminder, so my FPS and such might be out of wack, but the cameras work in zoneminder great.
I will monitor this post, so reply if i can help in any way.
Good luck!!
mrme
Tags to make it easy to find via search.
Linksys ip camera, cisco ip camera, cisco small business
Source=remote
Maximum FPS=30
Remote Host Port=80
Good luck!!
mrme
