BTSI Cams
VF
BTSI Cams
Post by VF »
Hi, I've recently buyed a BSTI PD100HV2 cam.
Could someone help me to get the videostream in ZM? I see the snapshot and videostream in the browser when I go on /snapshot.cgi and /videostream.cgi, respectively, on the remote machine, but it doesn't seem to work in ZM.
These are my configurations:
GENERAL:
Source type: remote
Function: monitor
Maximum FPS:30
SOURCE:
Remote host name: IP of the cam
Remote host port: port on which the cam works
remote host path: /videostream.cgi
remote image colours: 24 bit
capture width:320 / 640
capture height:240 / 480
Could some help to troubleshoot?
Thanks in advance!
kingofkya
Post by kingofkya »
When you go to the cgi url what size is the image because it must match what zm has in its size settings aka: the 320x480 you have currently. Also post some of your logs.
VF
Post by VF »
Hi, I don't know exactly the size of the image.
tha manual reports 320x240 and 640x480.
I've tried both, but it doesn't work.
Using vlc i can see the video stream with:
http://USERNAME:PASS@<CAM_ip>:PORT/videostream.cgi
but it doesn't works in ZM.
Sika
Post by Sika »
Have you checked your logs for shared memory errors?
VF
shared memory log
Post by VF »
No I didn't...I'm a newbie in IP CAM networking....
so could someone give me help/hints to:
1)look at shared memory logs
2)how could I get infos about video in streaming (FPS, resolution etc.) analyzing the source (I know IP and port, and mjpg coding).
For example..how could I exactly know the resolution (width/height) of the video in streaming?
Thanks a lot!
Sika
Post by Sika »
Logs on my ZM server are /var/logs/zm
You must be able to set the camera resolution/fps etc from the cameras web gui
VF
Logs and resolution
Post by VF »
the /var/log/zm dir is absolutely empty;
I cannot set the resolution of the cam on the configuration....I think it could be fixed.The manual only reports that it could be 320x240 or the double.
I would find a way to know which is the resolution, examining the tranport stream....
Sika
Post by Sika »
You could try pointing your ZM to BSTI web site demo camera.
This would narrow down where the problem is ie: If it doesn't work the
problem is with your ZM server.
Source type: remote
Function: monitor
Maximum FPS:15
SOURCE:
Remote host name: guest:guest@www.bsti.com.tw
Remote host port: 204
capture width:640
capture height:480
I get about 4fps to my ZM.
VF
Post by VF »
Hi (first of all thanks for your help :) ).
I've tried your configuration, and it doesn't works.
The strange thing is that if I use http://guest:guest@www.bsti.com.tw:204/videostream.cgi
in vlc, I'm able to see the video.
I think it's a problem of my ZM, but it's the same on 2 different machines (one physical and one virtualized).
Sika
Post by Sika »
Is your ZM installed with ffmpeg?
VF
ffmpeg
Post by VF »
Yes it is!
VF
The solution.
Post by VF »
I've found a solution...it was only a shared memory size problem.
editing the file /etc/sysctl.conf
appending this:
kernel.shmall = 564217728
kernel.shmmax = 564217728
now it works perfectly!
Next time I will active the debug logs, and look at the shared memory errors.
Thanks a lot!
