Video Generation
Posted: Fri Sep 25, 2009 12:53 pm
I followed the guide that is in:
http://www.zoneminder.com/forums/viewtopic.php?t=13578
works well, but I found a little problem and I wonder if anybody has been able to solve, is that after making changes to the file, which mensioanan in the guide, I disappeared the option to create a video of the event viewer
simply no longer exists the option
funciona bien, pero encontre un pequeño problema y quisiera saber si alguien lo ha podido solucionar, resulta que luego de realizar las modificaciones al archivo, que mensioanan en la guia, me desaparecio la opcion de crear un video en el visor de eventos
