Page 1 of 1
deleted events not deleted from disk
Posted: Fri Sep 25, 2009 1:07 pm
by verus
Is it normal that when i delete events in the browser, that these events are not deleted on disk ?
grtz, Ph.
Posted: Fri Sep 25, 2009 7:09 pm
by timcraig
It is normal when you have OPT_FAST_DELETE under the system options checked.
OPT_FAST_DELETE tell's zoneminder to simply delete the database records of an event when you delete them in the WebUI. The ZMAUDIT daemon in the background will periodically check for event folders of events that have been deleted and delete them.
You should see the events deleted off the disk eventually.
Posted: Sat Sep 26, 2009 4:20 am
by gola10
Does it applies to version 1.22.3? Because every momth i have to delete manually events older than 20 days where my hard disk size will not hold more than 7 days.
I has seen it in more than one installation. I thought it was due to database crash once i a while.
Posted: Mon Sep 28, 2009 8:05 am
by verus
I un-checked OPT_FAST_DELETE and restarted the server but it stays the same.
When deleting events, it's only in the GUI that the record is deleted and the files stay on the server.
bug ?
grtz, Ph.
