Images from other cameras "flickering" into camera
Posted: Tue Sep 29, 2009 6:17 pm
I have a weird issue, and I think it might be a shared memory issue.
I recently had a raid array crash and took the opportunity to upgrade to the latest zoneminder. I roughly followed the instructions from the zoneminder wiki.
OS Ubuntu 9.04 server
ZM 1.24.2
FFMPEG from svn, I can get the version if someone needs.
The image on the left is the problem, the image on the right is correct. I get periods where it works, and periods where it doesn't even show part of the correct image, as seen on the left.
ZM 1.24.2
root@gweld-camserv0:~# dmesg | grep bttv
[ 9.263545] bttv: driver version 0.9.17 loaded
[ 9.263548] bttv: using 8 buffers with 2080k (520 pages) each for capture
[ 9.263619] bttv: Bt8xx card found (0).
[ 9.263639] bttv 0000:03:08.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 9.263655] bttv0: Bt878 (rev 17) at 0000:03:08.0, irq: 16, latency: 64, mmio: 0xefff8000
[ 9.266954] bttv0: detected: Provideo PV150A-1 [card=98], PCI subsystem ID is aa00:1460
[ 9.266958] bttv0: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
[ 9.267002] bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 9.267064] bttv0: tuner absent
[ 9.267110] bttv0: registered device video0
[ 9.267130] bttv0: registered device vbi0
[ 9.267154] bttv0: PLL: 28636363 => 35468950 .. ok
[ 9.300058] bttv: Bt8xx card found (1).
[ 9.300080] bttv 0000:03:09.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 9.300098] bttv1: Bt878 (rev 17) at 0000:03:09.0, irq: 17, latency: 64, mmio: 0xefffa000
[ 9.300146] bttv1: detected: Provideo PV150A-2 [card=98], PCI subsystem ID is aa01:1461
[ 9.300152] bttv1: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
[ 9.300189] bttv1: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 9.300239] bttv1: tuner absent
[ 9.300288] bttv1: registered device video1
[ 9.300309] bttv1: registered device vbi1
[ 9.300334] bttv1: PLL: 28636363 => 35468950 .. ok
[ 9.340047] bttv: Bt8xx card found (2).
[ 9.340070] bttv 0000:03:0a.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 9.340087] bttv2: Bt878 (rev 17) at 0000:03:0a.0, irq: 18, latency: 64, mmio: 0xefffc000
[ 9.340145] bttv2: detected: Provideo PV150A-3 [card=98], PCI subsystem ID is aa02:1462
[ 9.340149] bttv2: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
[ 9.340187] bttv2: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 9.340239] bttv2: tuner absent
[ 9.340287] bttv2: registered device video2
[ 9.340308] bttv2: registered device vbi2
[ 9.340332] bttv2: PLL: 28636363 => 35468950 .. ok
[ 9.380045] bttv: Bt8xx card found (3).
[ 9.380066] bttv 0000:03:0b.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 9.380083] bttv3: Bt878 (rev 17) at 0000:03:0b.0, irq: 19, latency: 64, mmio: 0xefffe000
[ 9.380129] bttv3: detected: Provideo PV150A-4 [card=98], PCI subsystem ID is aa03:1463
[ 9.380133] bttv3: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
[ 9.380165] bttv3: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 9.380214] bttv3: tuner absent
[ 9.380260] bttv3: registered device video3
[ 9.380282] bttv3: registered device vbi3
[ 9.380305] bttv3: PLL: 28636363 => 35468950 .. ok
[ 9.420046] bttv: Bt8xx card found (4).
[ 9.420067] bttv 0000:02:08.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[ 9.420083] bttv4: Bt878 (rev 17) at 0000:02:08.0, irq: 20, latency: 64, mmio: 0xefef8000
[ 9.420135] bttv4: detected: Provideo PV150A-1 [card=98], PCI subsystem ID is aa00:1460
[ 9.420140] bttv4: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
[ 9.420178] bttv4: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 9.420228] bttv4: tuner absent
[ 9.420277] bttv4: registered device video4
[ 9.420302] bttv4: registered device vbi4
[ 9.420326] bttv4: PLL: 28636363 => 35468950 .. ok
[ 9.460047] bttv: Bt8xx card found (5).
[ 9.460074] bttv 0000:02:09.0: PCI INT A -> GSI 21 (level, low) -> IRQ 21
[ 9.460091] bttv5: Bt878 (rev 17) at 0000:02:09.0, irq: 21, latency: 64, mmio: 0xefefa000
[ 9.460144] bttv5: detected: Provideo PV150A-2 [card=98], PCI subsystem ID is aa01:1461
[ 9.460148] bttv5: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
[ 9.460197] bttv5: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 9.460246] bttv5: tuner absent
[ 9.460297] bttv5: registered device video5
[ 9.460319] bttv5: registered device vbi5
[ 9.460343] bttv5: PLL: 28636363 => 35468950 .. ok
[ 9.500042] bttv: Bt8xx card found (6).
[ 9.500058] bttv 0000:02:0a.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
[ 9.500072] bttv6: Bt878 (rev 17) at 0000:02:0a.0, irq: 22, latency: 64, mmio: 0xefefc000
[ 9.500099] bttv6: detected: Provideo PV150A-3 [card=98], PCI subsystem ID is aa02:1462
[ 9.500103] bttv6: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
[ 9.500142] bttv6: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 9.500191] bttv6: tuner absent
[ 9.500221] bttv6: registered device video6
[ 9.500242] bttv6: registered device vbi6
[ 9.500265] bttv6: PLL: 28636363 => 35468950 .. ok
[ 9.540048] bttv: Bt8xx card found (7).
[ 9.540071] bttv 0000:02:0b.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 9.540088] bttv7: Bt878 (rev 17) at 0000:02:0b.0, irq: 23, latency: 64, mmio: 0xefefe000
[ 9.540140] bttv7: detected: Provideo PV150A-4 [card=98], PCI subsystem ID is aa03:1463
[ 9.540144] bttv7: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
[ 9.540183] bttv7: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 9.540236] bttv7: tuner absent
[ 9.540287] bttv7: registered device video7
[ 9.540308] bttv7: registered device vbi7
[ 9.540333] bttv7: PLL: 28636363 => 35468950 .. ok
[ 27.467492] bttv0: PLL can sleep, using XTAL (28636363).
[ 27.963889] bttv1: PLL can sleep, using XTAL (28636363).
[ 28.494759] bttv2: PLL can sleep, using XTAL (28636363).
[ 29.037002] bttv3: PLL can sleep, using XTAL (28636363).
[ 29.611008] bttv4: PLL can sleep, using XTAL (28636363).
[ 30.141224] bttv5: PLL can sleep, using XTAL (28636363).
[ 30.749147] bttv6: PLL can sleep, using XTAL (28636363).
[ 31.340847] bttv7: PLL can sleep, using XTAL (28636363).
