I am trying to install ZoneMinder 1.24.2 from source to my sheevaplug (which is not x86 based) running Debian Lenny (5.0). ./configure runs without error but when I run the command run, I got:
zm_signal.cpp: In function ‘void zm_die_handler(int, sigcontext)’:
zm_signal.cpp:90: error: ‘struct sigcontext’ has no member named ‘cr2’
make[2]: *** [zm_signal.o] Error 1
make[2]: Leaving directory `/home/sysuser/dl/ZoneMinder-1.24.2/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/sysuser/dl/ZoneMinder-1.24.2'
make: *** [all] Error 2
Any ideas/suggestions?
