[solved]ZM+AVI202Z rtsp
Posted: Fri Oct 02, 2009 8:16 am
Hello
since 3 days I'm trying to use my cam with zm. I have read and do different topic like:
http://www.zoneminder.com/forums/viewtopic.php?t=10766
http://www.zoneminder.com/wiki/index.php/Vpipe
it's still don't work
I've try to use ZMMPEG4 but when i put the command line sudo zmmpeg4 status, i always hav the same answer :
root@Serveur:/etc/zm# sudo zmmpeg4 start
Starting server process.
root@Serveur:/etc/zm# sudo zmmpeg4 status
Server is not running.
I've tried all I can, vloopback is installed and modprobed :
root@Serveur:/etc/zm# lsmod | grep vloop
vloopback 22688 0
compat_ioctl32 18304 1 vloopback
videodev 45184 2 vloopback,compat_ioctl32
my cam works well with vlc with a command line like :
rtsp:// admin:admin@192.168.1.10/live/mjpeg
I dont' have any idea.. could somebody help me please?
PS : i'm running on UBUNTU 9.04 and I use v1.23.3. of ZM i've tried to compile and install 1.24.1 and 2 version of ZM but i've a compilation error :
zm_mpeg.cpp:325: erreur: ‘img_convert’ was not declared in this scope
make[2]: *** [zm_mpeg.o] Erreur 1
so I use the official release with apt-get install zoneminder
edit : my problem is solved with the new version 1.24
vloopback 22688 0
