Help in 1.24
Posted: Mon Oct 05, 2009 8:52 pm
list, I need your help, turns out I have a capture card Kodicom 8800, with 8 cameras PAN - Philips CCD, installed in Centos 5.3
Everything works fine, but the image quality is not good, when compared with the same system installed on Windows XP and the software that comes with the motherboard Kodicom
My current configuration is:
modprobe.conf:
options i2c-algo-bit bit_test=1
options bttv gbuffers=32 radio=-1 tuner=4 card=102,102,102,102,102,102,102,102,102,102,102,102,102,102,102,102 coring=1 full_luma_range=1 chroma_agc=1 combfilter=1 autoload=0 triton1=0 vsfx=0
in Zm
config:
V4L_MULTI_BUFFER : disable
CAPTURES_PER_FRAME: 1
in images
CAN_STREAM: auto
STREAM_METHOD: jpeg
JPEG_FILE_QUALITY: 85
MPEG_LIVE_FORMAT : swf
OPT_CAMBOZOLA : enable
Monitors:
PAL
320*240
V4l2
colour: yuv422P
FPS : 25
Also when using jpeg, I can see multiple camera because I always show the same monitor
modprobe.conf:
in Zm
config:
in images
CAN_STREAM: auto
STREAM_METHOD: jpeg
Monitors:
PAL
320*240
V4l2
colour: yuv422P
FPS : 25
