Page 1 of 1
Video stream MPEG - Problem
Posted: Thu Oct 08, 2009 1:44 pm
by sezamnet
Hello.
I have a problem with the transmission image in the form of encoded mpeg.
ZM install the package. Rpm
http://liquid-co.de/pub/suse/repositori ... .1/x86_64/
ZM settings:
ZM_STREAM_METHOD: mpeg
When I run view of the camera I see a black screen, in the case of jpeg everything is working properly.
log error:
ZMS [23,217]: ERR [MPEG streaming of 'mode=mpeg&display=1&scale=100$bitrate=150000&maxfps=15&format=asf&auth=xxxxxxxxxxxxxx&rand=1255009116' attempted while disabled]
PLS Help
now log
Posted: Fri Oct 09, 2009 2:56 pm
by sezamnet
I uinstall libavformat and install back, and I heve now that error.
zms[18299]: ERR [Got signal (Segmentation fault), crashing]
zms[18299]: ERR [Signal address is 66054, no eip ]
zms[18299]: ERR [Backtrace: /lib64/libc.so.6 [0x7f4745d2b6e0]]
zms[18299]: ERR [Backtrace: /usr/lib64/libavformat.so.52(ff_metadata_mux_compat+0x27) [0x7f4748040107]]
zms[18299]: ERR [Backtrace: /usr/lib64/libavformat.so.52(av_write_header+0x15a) [0x7f474804561a]]
zms[18299]: ERR [Backtrace: /srv/www/cgi-bin/nph-zms [0x41deaa]]
zms[18299]: ERR [Backtrace: /srv/www/cgi-bin/nph-zms [0x41e7e5]]
zms[18299]: ERR [Backtrace: /srv/www/cgi-bin/nph-zms [0x404708]]
zms[18299]: ERR [Backtrace: /lib64/libc.so.6(__libc_start_main+0xe6) [0x7f4745d17586]]
zms[18299]: ERR [Backtrace: /srv/www/cgi-bin/nph-zms [0x403e19]]
zms[18299]: INF [Backtrace complete]
my ffmpeg version:
FFmpeg version UNKNOWN, Copyright (c) 2000-2009 Fabrice Bellard, et al.
configuration: --prefix=/usr --mandir=/usr/share/man --libdir=/usr/lib64 --shlibdir=/usr/lib64 --enable-pthreads --enable-shared --enable-avfilter --disable-static --enable-libmp3lame --enable-libfaad --enable-libfaadbin --enable-libxvid --enable-libx264 --enable-postproc --enable-shared --enable-libdc1394 --enable-libtheora --enable-gpl --enable-version3
libavutil 50. 3. 0 / 50. 3. 0
libavcodec 52.35. 0 / 52.35. 0
libavformat 52.38. 0 / 52.38. 0
libavdevice 52. 2. 0 / 52. 2. 0
libavfilter 0. 5. 0 / 0. 5. 0
libswscale 0. 7. 1 / 0. 7. 1
libpostproc 51. 2. 0 / 51. 2. 0
built on Sep 15 2009 00:44:14, gcc: 4.3.1 20080507 (prerelease) [gcc-4_3-branch revision 135036]
At least one output file must be specified
Instalation ZM: ZoneMinder-MP-1.23.3.rpm
