Hello. List, I have Zm working with 11 cameras, and really doing very well, but I have a problem with Internet Explorer (7 and , I can see multiple cameras (group),
Zm is in MPEG STREAM_METHOD and SWF MPEG_REPLAY_FORMAT + cambozola active.
does not work in IE but if I put jpeg if it works without problems
jpeg but actually consume too much bandwidth.
only works OK in firefox with mpeg + swf
error to see multiple cameras
Do you have the last version of ZM 1.24.2 ?
Because I have the same problem in JPEG stream (in firefox or IE)
I can not see multicam and the resolution is limited to 320x240
If I configure the stream resolution in 640x480
no error, color status of detection are ok, but nothin in the browser !
What would you like to use software to broadcast in mpeg or swf stream ?
VLC ? FFmpeg ?
VLC ? FFmpeg ?
