this is a error?
arielf
this is a error?
Post by arielf »
when I run a tail-f / var / log / messages
This legend is always me
is a configuration error?
ERR [Frame send time 8970 msec too slow, throttling maxfps to 2.22]
zms[17125]: ERR [Terminating, last frame sent time 10.020236 secs more than maximum of 10.000000]
Centos 5.3
marculin
Post by marculin »
up!
I've same log
kingofkya
Post by kingofkya »
It means your overloading you system. Most likely you have a high load. which is causing it to capture at a lower rate. Try tweaking the option skip frames. (it skips frames only for the motion detect). it in the camera settings
