I really need some Help please thank you
Posted: Sun Oct 18, 2009 12:06 am
I just want someone who can help me or explain me exactly where is my problem on the configuration zoneminder
I'm professionnal of asterisk solution VoIP but not on the Zoneminder and I really want to try to connecte my asterisk and zoneminder but unfortunatly is't more hard as I was thinking
Todays my zoneminder is running but I cannot see any camera on the screen : I'll explain to you more and I hope you can help me little bit thank you.
I have 2 caméra WVC2300 and WVC210 and this camera work if I'm using the link http access direct by the server WEB inside on the camera so this is the link I use to see directly on the firefox
http://user:password@IP_Server/img/video.mjpeg this is for both of the camera WVC210 ans also WVC2300 and is working ok!
so that is normal for the moment ok and I prefer to configure my camera WVC2300 on RTSP protocol to using on zoneminder .
So I catch the signal video directly on VLC I only do that just to be sure the RTSP is working and It's ok I can see direct on VLC with the WVC2300 but the RTSP for the WVC210 it is not working because I didn't find the right path beacause is not the same as below
rtsp://192.168.1.100:554/img/video.MPEG-4%20SP this work on VLC for WVC2300 but not with WVC210.
OK let talk now onn my zoneminder problem
so this is the problem I put both of the camera on zoneminder and I can't see any flux video on the creen, I tried both of the config one with HTTP and the other one with RTSP and same problem no video???? Zoneminder writting running I can stop and start without problem so everything looks like correct but can not find the video flux on both camera
this is the configuration on my 2 camera
screen - WVC230 RTST
* General
Name WVC2300
Source Type remote
Fonction monitor
Activity yes stick
i/s maximum 30.00
Alarm Maximum FPS nothing
Reference Image Blend %ge 7
* Source
Remote Protocol RTSP
Remote Method RTP/RTSP
Remote Host Name 192.168.1.100
Remote Host Port 554
Remote Host Path img/video.MPEG-4%20SP
Remote Image Colours 24bit
Larg. capture (pixels) 320
Haut. capture (pixels) 240
Preserve Aspect Ratio no stick
screen - WVC210 HTTP
* General
Name WVC210
Source Type remote
Fonction monitor
Activity yes stick
i/s maximum 30.00
* Source
Remote Protocol HTTP
Remote Method SIMPLE
Remote Host Name 192.168.1.101
Remote Host Port 80
Remote Host Path img/video.mjpeg
Nom Fonction Source Evènts Heure Jour Semaine Mois Archived Zones Order Marque
0 0 0 0 0 0 1
WVC2300 Monitor 192.168.1.205 0 0 0 0 0 0 1 UpDown
WVC210 Monitor 192.168.1.204 0 0 0 0 0 0 0 UpDown
and Nothing work so if someone can help me to explain me exactly where is my problem it'll be great thank you a lot
ps: sorry for my bad english I try to do the best as I can
Cordialy
Diablo
* General
Name WVC2300
Source Type remote
Fonction monitor
Activity yes stick
i/s maximum 30.00
* Source
* General
Name WVC210
Source Type remote
Fonction monitor
Activity yes stick
i/s maximum 30.00
* Source
Remote Host Port 80
0 0 0 0 0 0 1
Cordialy
Diablo
