If I config zoneminder to get video from a file , what format should the file be?
Does a jpeg file work?
Question about format of "source - file device"
- zoneminder
- Site Admin
- Contact:
Hi!
This seems like a really interesting feature, but I'm not sure I got it right... ZM takes a jpeg image as it's source right? That means that it should be able to display whatever jpeg I put on the source path??
I can't manage to make it work
Could someone give me a little hint please?
This is my configuration
ZM: 1.24.1
Source Type: File
Function: Monitor
Source path: /home/chika_nidza/test.jpg
Capture Width: 350
Capture Height: 240
When I try to see the monitor, nothing happens (only a black screen).
Anyone uses this feature? Thanks in advance for your advice!!!
ZM: 1.24.1
Source Type: File
Function: Monitor
Capture Width: 350
Capture Height: 240
