Can't Start Zoneminder
m3bik
Post by m3bik »
I have Fedora 10 running Zoneminder 1.23.3. I installed it by simply using
yum install zoneminder
Everything is running, but when I go to http://localhost/zm the title says ZoneMinder Console - Stopped... When I click it and try to start it, it acts like it's starting it, but when it reloads the home page, it still says ZomeMinder Console - Stopped... It does not start! Any ideas?
m3bik
Post by m3bik »
I found the problem. SELinux was causing issues. I ran
setenforce 0
and then restarted zoneminder...problem solved!
