Hello
I have the Level One FCS 5030.
When I look at my ZM log I can see that I only record at 7-9 fps.
Oct 28 22:02:02 mistik zma_m1[31782]: INF [GarageParkering: 536000 - Processing at 8.33 fps]
Oct 28 22:02:39 mistik zmc_m1[2568]: INF [GarageParkering: 3181000 - Capturing at 8.55 fps]
Oct 28 22:04:01 mistik zma_m1[31782]: INF [GarageParkering: 537000 - Processing at 8.40 fps]
Oct 28 22:04:39 mistik zmc_m1[2568]: INF [GarageParkering: 3182000 - Capturing at 8.33 fps]
Why isn't it capturing at 25 fps which the camera & ZM is set to? What is the limitation?
My settings in the camera are:
PAL
Enable cutting noise
MPEG-4
688x576
25 fps
Intra frame period: 1s
Fixed quality: Excellent
And in ZM:
RTP/RTSP
/live.sdp
same res & fps
Then one more question, what is the intra frame period? I can set the value between 1/4s to 4s.
Two questions on Level-1 FCS 5030, low fps & intra frame
