help, script to generate an MPEG video per day
arielf
Post by arielf »
someone has any script to take an example, since I need to create a single mpeg file per day with events generated by each monitor.
alguien , tiene algun script, para tomar de ejemplo , ya que necesito generar un solo archivo mpeg por dia con los eventos que genera cada monitor.
trendkill
Re: help, script to generate an MPEG video per day
Post by trendkill »
here is the script:
http://www.zoneminder.com/forums/viewtopic.php?p=56997
but i can't run it. Please, if you can, tell me how.
arielf wrote:someone has any script to take an example, since I need to create a single mpeg file per day with events generated by each monitor.
zoneminder
Site Admin
Post by zoneminder »
There will be something coming in the 'official' distro that will do this for you fairly shortly if you can wait a bit.
Phil
arielf
Post by arielf »
thanks, for the tip,, how much time is? probandondolo way to go there?
redebeer
script
Post by redebeer »
If you havnt found solution yet, read the post on the link http://www.zoneminder.com/forums/viewtopic.php?p=56997 almost in the middle, one guy wrote (run/terminal) : /usr/bin//php <filename>
where filename = the name of the script...so if you've saved the script as /home/genscript
then you will have /usr/bin/php /home/genscript
And like the next guy posted, it would be better to have cron setup to do it daily for you
