Page 1 of 1
help, script to generate an MPEG video per day
Posted: Thu Oct 29, 2009 8:06 pm
by arielf
someone has any script to take an example, since I need to create a single mpeg file per day with events generated by each monitor.
alguien , tiene algun script, para tomar de ejemplo , ya que necesito generar un solo archivo mpeg por dia con los eventos que genera cada monitor.
Re: help, script to generate an MPEG video per day
Posted: Fri Oct 30, 2009 8:05 pm
by trendkill
here is the script:
http://www.zoneminder.com/forums/viewtopic.php?p=56997
but i can't run it. Please, if you can, tell me how.
arielf wrote:someone has any script to take an example, since I need to create a single mpeg file per day with events generated by each monitor.
Posted: Mon Nov 02, 2009 12:20 pm
by zoneminder
There will be something coming in the 'official' distro that will do this for you fairly shortly if you can wait a bit.
Posted: Mon Nov 02, 2009 12:33 pm
by arielf
thanks, for the tip,, how much time is? probandondolo way to go there?
script
Posted: Mon Jan 18, 2010 11:05 am
by redebeer
If you havnt found solution yet, read the post on the link
http://www.zoneminder.com/forums/viewtopic.php?p=56997 almost in the middle, one guy wrote (run/terminal) : /usr/bin//php <filename>
where filename = the name of the script...so if you've saved the script as /home/genscript
then you will have /usr/bin/php /home/genscript
And like the next guy posted, it would be better to have cron setup to do it daily for you
