OpenSuse 11.1 Error "Could not open config file."
mikeeyy
Post by mikeeyy »
hi there,
i used this documentation http://www.zoneminder.com/wiki/index.ph ... ZoneMinder to install ZoneMinder on a new opensuse 11.1 installation. the server is a Strato provider root system with plesk 9.2.
the installation finished with no errors. the installation take place in /svr/www/vhosts/mydomain/httpdocs/zm
owner of the directory and files are wwwrun
the zm.config is located in /usr/local/etc
after installation i tried to load the mainpage. but i only get an error "Could not open config file." after spending the last two days and trying to find a solution i have no more ideas whats the problem.
i tried also an rpm installation. but i got the same error message.
hope you can help me.
thank you verry much!
greetings
mike
kevin_robson
Post by kevin_robson »
I assume you meant zm.conf and not zm.config?
It should also be owned by the owner of the web server - on suse wwwrun
ls -l
total 4
-rw------- 1 wwwrun www 1375 Jun 30 20:08 zm.conf
