INSTALL SERVER OS
Install Ubuntu Server PPC-PS3. Do not install any packages other than openssh-server.
GO SUDO AND STAY THERE FOR ENTIRE INSTALLATION
sudo -i
UPDATE SERVER OS
apt-get update; apt-get dist-upgrade
GET RID OF NON-COMPATIBLE FFMPEG STUFF
apt-get autoremove ffmpeg
apt-get autoremove x264
apt-get autoremove libx264-dev
ADD THIS STUFF FOR DOING OTHER FFMPEG STUFF
apt-get install build-essential subversion git-core checkinstall yasm texi2html libfaac-dev libfaad-dev libmp3lame-dev libsdl1.2-dev libtheora-dev libx11-dev libxvidcore4-dev zlib1g-dev
INSTALL x264
cd /usr/src
git clone git://git.videolan.org/x264.git
cd x264
./configure
make
sudo checkinstall --fstrans=no --install=yes --pkgname=x264 --pkgversion "1:0.svn`date +%Y%m%d`-0.0ubuntu1" --default
CHANGES FOR LIB PATHS
echo "/usr/local/lib" > /etc/ld.so.conf.d/ffmpeg.conf
echo "LD_LIBRARY_PATH=/usr/local/lib:$LD_LIBRARY_PATH" >> /etc/bash.bashrc
echo "export LD_LIBRARY_PATH" >> /etc/bash.bashrc
ldconfig
INSTALL ALL ZONEMINDER PREREQUISITES
apt-get install build-essential linux-headers-`uname -r` automake perl libnet-ssleay-perl openssl libauthen-pam-perl libpam-runtime libio-pty-perl libmd5-perl apache2 php5-mysql libapache2-mod-php5 mysql-server libmysqlclient15-dev libarchive-zip-perl libdate-manip-perl libdevice-serialport-perl libjpeg62 libjpeg62-dev libmime-perl libstdc++6 libwww-perl zlib1g zip unzip patch ntp openssl libpcre3-dev libssl-dev libjpeg-progs libcurl4-gnutls-dev munin munin-node libmime-lite-perl netpbm libbz2-dev subversion sysvinit-utils checkinstall
INSTALL PERL MODULES
perl -MCPAN -e shell
install CPAN
exit
install YAML PHP::Serialization Module::Load X10::ActiveHome
exit
INSTALL FFMPEG
cd /usr/src
svn checkout svn://svn.mplayerhq.hu/ffmpeg/trunk ffmpeg
cd ffmpeg
./configure --enable-gpl --enable-shared --enable-nonfree --enable-pthreads --enable-libfaac --enable-libfaad --enable-libmp3lame --enable-libtheora --enable-libx264 --enable-libxvid --enable-x11grab
make
checkinstall --fstrans=no --install=yes --pkgname=ffmpeg --pkgversion "3:0.svn`date +%Y%m%d`-12ubuntu3" --default
ldconfig
SETUP FFMPEG PATHS SO THAT OTHER UBUNTU APPS CAN FIND IT
cd /usr/bin/
ln -s /usr/local/bin/ffmpeg ./ffmpeg
ln -s /usr/local/bin/ffplay ./ffplay
ln -s /usr/local/bin/ffserver ./ffserver
ln -s /usr/local/bin/x264 ./x264
INSTALL AND CONFIGURE ZONEMINDER
cd /usr/src
svn co http://svn.zoneminder.com/svn/zm/trunk zm
cd zm
./configure --with-webdir=/var/www --with-cgidir=/usr/lib/cgi-bin ZM_DB_HOST=localhost ZM_DB_NAME=zm ZM_DB_USER=zmuser ZM_DB_PASS=zmpass --enable-debug=no --with-webgroup=www-data --with-webuser=www-data --disable-crashtrace
aclocal
autoconf
automake
If you are using Ubuntu 9.10 (karmic) or an OS that uses gcc 4.4.0 you will need to add this to your src/zm_utils.cpp:
#include <cstdio>
make
mysql -u root -p < db/zm_create.sql
mysql -u root -p
grant select,insert,update,delete on zm.* to 'zmuser'@localhost identified by 'zmpass';
flush privileges;
quit
checkinstall --fstrans=no --install=yes --pkgname=ZoneMinder --pkgversion "1.24.svn`date +%Y%m%d`" --default
INSTALL CAMBOZOLA
cd /usr/src
wget http://www.charliemouse.com:8080/code/cambozola/cambozola-latest.tar.gz
tar -xzvf cambozola-latest.tar.gz
cp cambozola-0.76/dist/cambozola.jar /var/www
INSTALL JSCALENDAR
cd /usr/src
wget http://prdownloads.sourceforge.net/jscalendar/jscalendar-1.0.zip?download
unzip jscalendar-1.0.zip
mkdir /var/www/tools/jscalendar
cp -R jscalendar-1.0/* /var/www/tools/jscalendar
REMOVE EXISTING index.html
rm /var/www/index.html
CREATE ZONEMINDER STARTUP SCRIPT
**If you don't know how to use vi then use nano instead for next stop**
vi /etc/init.d/zm
(PASTE THE FOLLOWING)
#!/bin/sh
# description: Control ZoneMinder as a Service
# chkconfig: 2345 99 99
# Source function library.
#. /etc/rc.d/init.d/functions
prog=ZoneMinder
ZM_PATH_BIN="/usr/local/bin"
command="$ZM_PATH_BIN/zmpkg.pl"
start() {
echo -n "Starting $prog: "
$command start
RETVAL=$?
[ $RETVAL = 0 ] && echo success
[ $RETVAL != 0 ] && echo failure
return $RETVAL
stop() {
echo -n "Stopping $prog: "
$command stop
RETVAL=$?
status() {
result=`$command status`
if [ "$result" = "running" ]; then
echo "ZoneMinder is running"
RETVAL=0
else
echo "ZoneMinder is stopped"
RETVAL=1
fi
case "$1" in
'start')
start
'stop')
stop
'restart')
stop
start
'status')
status
echo "Usage: $0 { start | stop | restart | status }"
RETVAL=1
esac
exit $RETVAL
(SAVE AND EXIT)
MAKE ZM STARTUP SCRIPT EXECUTABLE
chmod 755 /etc/init.d/zm
UPDATE /etc/rc.local TO START ZONEMINDER UPON REBOOT
vi /etc/rc.local
ADD THESE LINES:
#Start Zoneminder
/etc/init.d/zm start
REBOOT THE SERVER
/sbin/shutdown now -r
If you use the above installation guide you may see some issues with timestamps with a date of 12/31/1969. I had to install mysqltuner and tweak my my.cnf file and haven't seen the issue happen since.
I had asked for help and cordel responded that it is probably an issue with mysql and he recommended that I tune mysql:
http://www.zoneminder.com/forums/viewtopic.php?t=14410
TO DO THIS FIRST INSTALL mysqltuner:
sudo -i
apt-get install mysqltuner
STOP ZONEMINDER
/etc/init.d/zm stop
STOP MYSQL
/etc/init.d/mysql stop
EDIT YOUR my.cnf FILE
vi /etc/mysql/my.cnf
UNCOMMENT skip-innodb OR ADD IT IF IT IS NOT IN THERE
MAKE SURE THE THE FOLLOWING PARAMETERS ARE SET:
key_buffer = 16M
max_allowed_packet = 32M
thread_stack = 128K
thread_cache_size = 8
query_cache_limit = 1M
query_cache_size = 24M
ADD THESE PARAMETERS:
tmp_table_size = 32M
max_heap_table_size = 16M
SAVE AND EXIT
START MYSQL
/etc/init.d/mysql start
START ZONEMINDER
IF YOU WANT TO TUNE YOUR OWN SYSTEM, LET YOUR SYSTEM RUN NORMALLY FOR ABOUT 15 MINUTES AND THEN RUN:
mysqltuner
IT WILL ASK YOU FOR YOUR MYSQL ROOT USERNAME AND PASSWORD SO ENTER IT
ONCE YOU ENTER YOUR USERNAME AND PASSWORD IT WILL GIVE YOU SOME RECOMMENDATIONS. I WOULD GUESS THAT IF YOU APPLY THE ABOVE SETTINGS IT WILL NOT RECOMMEND ANY CHANGES.
You can disregard this:
General recommendations:
Enable the slow query log to troubleshoot bad queries
You will probably find that your system will run with greater efficiency
