I have tried changing form record to mocord with same results. I have also tried gray color, changing resolution, length of the recording block (900 sec), with the same results.
Any one have any idea why ZM is behaving like this?
I see errors in the logs:
zmdc.log
1/10/09 07:15:14.196523 zmdc[27842].INF ['zmwatch.pl' starting at 09/11/10 07:15:14, pid = 11963]
11/10/09 10:05:30.773947 zmdc[27842].ERR ['zma -m 4' exited abnormally, exit status 214]
11/10/09 10:05:30.774459 zmdc[27842].INF [Starting pending process, zma -m 4]
11/10/09 10:05:30.776074 zmdc[27842].INF ['zma -m 4' starting at 09/11/10 10:05:30, pid = 8568]
11/10/09 10:05:32.735239 zmdc[27842].ERR ['zma -m 5' exited abnormally, exit status 214]
11/10/09 10:05:32.735733 zmdc[27842].INF [Starting pending process, zma -m 5]
11/10/09 10:05:32.737279 zmdc[27842].INF ['zma -m 5' starting at 09/11/10 10:05:32, pid = 8569]
11/10/09 10:09:05.471244 zmdc[27842].ERR ['zma -m 6' exited abnormally, exit status 214]
11/10/09 10:09:05.471749 zmdc[27842].INF [Starting pending process, zma -m 6]
11/10/09 10:09:05.473354 zmdc[27842].INF ['zma -m 6' starting at 09/11/10 10:09:05, pid = 9067]
zmfilter[27905].ERR [Can't execute filter 'select E.Id,E.MonitorId,M.Name as MonitorName,M.DefaultRate,M.DefaultScale,E.Name,E.Cause,E.Notes,E.StartTime,unix_timestamp(E.StartTime) as Time,E.Length,E.Frames,E.AlarmFrames,E.TotScore,E.AvgScore,E.MaxScore,E.Archived,E.Videoed,E.Uploaded,E.Emailed,E.Messaged,E.Executed from Events as E inner join Monitors as M on M.Id = E.MonitorId where not isnull(E.EndTime) and ( E.StartTime >= '2009-11-10 20:31:43' and M.Id = '1' and ( weekday( E.StartTime ) = 4 and extract( hour_second from E.StartTime ) >= extract( hour_second from '2009-11-10 01:15:00' ) and extract( hour_second from E.StartTime ) <extract>= 4 and E.AlarmFrames >= 5 ) and ( E.Archived = 0 or E.Emailed = 0 or E.Messaged = 0 ) order by E.StartTime asc', ignoring: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'order by E.StartTime asc' at line 1]
