Mapped memory
Posted: Thu Nov 12, 2009 1:23 pm
Hello guys, im having some troubles with (the classic) the memory.
I upgraded from 1.23 to 1.24.2, using shared memory. After upgrade i had tons of problems with "Can't get shared memory id", after playing with the sysctrl parameters, with no luck, i decided to recompile zm with mmap, compiled, installed it, but no luck.
The weid thing is that i have nothing on /dev/shm and i keep getting Can't get shared memory id errors.
Looks like it havent compiled with mmap.
./configure --enable-mmap=YES --with-cgidir=/var/www/cgi-bin/ -with-webdir=/var/www/html/video/
any idea how i can check this?
cheers!
cheers!
