I have a p3 1 gig box with 512 meg of ram
I have a KMC4400 card
I have loaded Ubuntu on this computer and installed the card.
I have followed the install instructions for Zone Minder and have successfully set up the software. I can access the software from a browser on any computer in my house.
I set up the source exactly how the zoneminder instructions call out.
my source device is now set to /dev/video0 (0) but it is red
the function is orange
I have looked through the wiki and have found
http://www.zoneminder.com/wiki/index.php/Kodicom_4400r
I tried resetting the bttv file to the suggested parameters and still no luck
I loaded XawTV as suggested in a couple of other forum threads and was able to view an input signal on composite0
My Bttv.conf file looks like this right now.
options bttv gbuffers=16 card=0x85,0x84,0x85,0x85 tuner=4 radio=0 coring=1 full_luma_range=1 chroma_agc=1 combfilter=1 autoload=0 triton1=0 vsfx=0
I only have one monitor set up.
I am pulling my hair out.
any ideas???????
Need help with initial setup
OK I just looked at the message file and pulled this off of the end. not sure what it means but sure looks like something isnt working right. as far as the camera setup goes
/dev/video0, 320x240, ntsc m, 24rgb, maxfps 15,
by the way I have successfully captured video and stills using XawTV.
Nov 19 20:48:18 Camerabox zmc_dvideo0[2564]: INF [Starting Capture]
Nov 19 20:48:18 Camerabox zmc_dvideo0[2564]: INF [Got signal 6 (Aborted), exiting and forcing backtrace]
Nov 19 20:48:36 Camerabox zmdc[2233]: WAR [Can't find process with command of 'zma -m 4']
Nov 19 20:48:37 Camerabox zmdc[2569]: INF ['zmc -d /dev/video0' started at 09/11/19 20:48:37]
Nov 19 20:48:37 Camerabox zmdc[2233]: INF ['zmc -d /dev/video0' starting at 09/11/19 20:48:37, pid = 2569]
Nov 19 20:48:37 Camerabox zmc_dvideo0[2569]: INF [Debug Level = 0, Debug Log = <none>]
Nov 19 20:49:17 Camerabox zmdc[2233]: INF [Starting pending process, zmc -d /dev/video0]
Nov 19 20:49:17 Camerabox zmdc[2233]: INF ['zmc -d /dev/video0' starting at 09/11/19 20:49:17, pid = 2578]
Nov 19 20:49:17 Camerabox zmdc[2578]: INF ['zmc -d /dev/video0' started at 09/11/19 20:49:17]
Nov 19 20:49:17 Camerabox zmc_dvideo0[2578]: INF [Debug Level = 0, Debug Log = <none>]
Nov 19 20:50:05 Camerabox zmdc[2233]: WAR [Can't find process with command of 'zmc -m']
Nov 19 20:50:06 Camerabox zmdc[2233]: WAR [Can't find process with command of 'zma -m']
Nov 19 20:50:15 Camerabox zms[2597]: INF [Debug Level = 0, Debug Log = <none>]
Nov 19 20:50:15 Camerabox zms[2597]: WAR [Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results]
Nov 19 20:50:15 Camerabox zms[2597]: WAR [Unable to store frame as shared memory invalid]
Nov 19 20:50:37 Camerabox zmdc[2233]: INF [Starting pending process, zmc -d /dev/video0]
Nov 19 20:50:37 Camerabox zmdc[2233]: INF ['zmc -d /dev/video0' starting at 09/11/19 20:50:37, pid = 2598]
Nov 19 20:50:37 Camerabox zmdc[2598]: INF ['zmc -d /dev/video0' started at 09/11/19 20:50:37]
Nov 19 20:50:37 Camerabox zmc_dvideo0[2598]: INF [Debug Level = 0, Debug Log = <none>]
Nov 19 20:50:37 Camerabox zmc_dvideo0[2598]: INF [Starting Capture]
Nov 19 20:50:37 Camerabox zmc_dvideo0[2598]: INF [Got signal 6 (Aborted), exiting and forcing backtrace]
Nov 19 20:50:37 Camerabox zms[2597]: WAR [Unable to store frame as timestamp invalid]
Nov 19 20:50:59 Camerabox zms[2597]: WAR [Rewound over write index, resuming live play]
Nov 19 20:51:08 Camerabox zms[2597]: WAR [Rewound over write index, resuming live play]
Nov 19 20:53:17 Camerabox zmdc[2233]: INF [Starting pending process, zmc -d /dev/video0]
Nov 19 20:53:17 Camerabox zmdc[2233]: INF ['zmc -d /dev/video0' starting at 09/11/19 20:53:17, pid = 2604]
Nov 19 20:53:17 Camerabox zmdc[2604]: INF ['zmc -d /dev/video0' started at 09/11/19 20:53:17]
Nov 19 20:53:17 Camerabox zmc_dvideo0[2604]: INF [Debug Level = 0, Debug Log = <none>]
Nov 19 20:53:17 Camerabox zmc_dvideo0[2604]: INF [Starting Capture]
Nov 19 20:53:17 Camerabox zmc_dvideo0[2604]: INF [Got signal 6 (Aborted), exiting and forcing backtrace]
R32
