Ubuntu 9.10 zoneminder doesn't work
Posted: Thu Nov 19, 2009 2:31 pm
Hello.
I have just installed Zoneminder 1.24.1 from Ubuntu 9.10 repository.
I have two cams to configure.
USB Philips web cam
Axis 207w IP web cam.
I have been able to configure (set up) both cams, but anyone works properly.
USB Cam
I see a static black scream nothing more happens
IP (remote) Cam
I can’t see anything, only a static white scream.
I have just read zm.conf and apache2.conf configurations files.
Both files are correct (normal).
Also I have been searching for a solution in the forum and wiki, and I haven’t found anything useful.
USB cams configuration:
Source Type: Local
Function: Monitor
Maximum FPS: none
Alarm Maximum FPS: none
Device Path: /dev/video
Capture Method for linux version 2
Device Channel: 0
Device Format: PAL B
Capture Palette: RGB 24
With: 320
Height: 240
IP cams Configuration
I have done part of the configuration using preset options.
Preset option: Axis IP, 640x480, jpeg
Function: Monitor
Remote Host name: xxx.yyy.zzz.sss (Web cans IP address)
With each cam and configuration in the main scream (ZM – Console) the source column is in red.
I have copied the last few records of the zmwatch.log.
Always the same message appears:
19/11/09 15:01:58.128352 zmwatch[2792].ERR [Can't get shared memory id '7a6d0002', 2: No existe el fichero ó directorio]
19/11/09 15:01:58.128776 zmwatch[2792].ERR [Can't get shared memory id '7a6d0002', 2: No existe el fichero ó directorio]
19/11/09 15:02:08.130227 zmwatch[2792].ERR [Can't get shared memory id '7a6d0002', 2: No existe el fichero ó directorio]
19/11/09 15:02:08.130594 zmwatch[2792].ERR [Can't get shared memory id '7a6d0002', 2: No existe el fichero ó directorio]
19/11/09 15:02:18.132229 zmwatch[2792].ERR [Can't get shared memory id '7a6d0002', 2: No existe el fichero ó directorio]
19/11/09 15:02:18.132581 zmwatch[2792].ERR [Can't get shared memory id '7a6d0002', 2: No existe el fichero ó directorio]
I have tried these solutions without success:
I have tried to compile the source code with –enable-nmap=yes option but when I execute “make installâ€
USB Philips web cam
USB Cam
IP (remote) Cam
Source Type: Local
Function: Monitor
Maximum FPS: none
Device Channel: 0
With: 320
Height: 240
Function: Monitor
