I can see the ZM webpages fine in the webserver and ZM talks to the database on Mysql fine as im able to update settings and they take...
when I try and execute Service zoneminder start here is the output I get at the console:
[root@zoneminder ZoneMinder]# service zoneminder start
Starting zoneminder: Can't connect: Permission denied at /usr/lib/perl5/vendor_perl/5.10.0/ZoneMinder/Debug.pm line 349
ZoneMinder::Debug::Fatal('Can\'t connect: Permission denied') called at /usr/bin/zmdc.pl line 168
[FAILED]
Nov 24 05:08:29 localhost zmpkg[2546]: INF [Command: start]
Nov 24 05:08:30 localhost zmfix[2557]: INF [New Debug Level = 4, New Debug Log = /var/log/zoneminder/zm_debug.log.02557]
Nov 24 05:08:30 localhost zmdc[2561]: INF [Server starting at 09/11/24 05:08:30]
Nov 24 05:08:33 localhost zmdc[2561]: FAT [Can't bind: Address already in use]
Nov 24 05:08:40 localhost zmdc[2559]: FAT [Can't connect: Permission denied]
Nov 24 05:08:41 localhost zmpkg[2546]: ERR [Unable to run "sudo -u apache /usr/bin/zmdc.pl startup", output is "Starting server"]
anyone have any ideas? do I have a file in an incorrect group?
-Christopher
