DLink DCS-3220G problems
npham
Post by npham »
I have read through a few posts and the FAQ on the Wiki, but I did not see if the wireless G version(revB) works properly. I can see that a lot of people have success setting up the 3220, but I have the G version and cannot find a definite answer.
Also, if this works/compatible, there is something I must be missing. I've entered in the data from the FAQ into the Source tab of the Monitor console, but all I get is black screen. I can access the camera(through its IP), and see that it is in fact functioning, but for the life of me I cannot get Zoneminder to work with it. I've removed any users, and the admin password through the Dlink software when you access the camera by IP as well.
Does anyone have any suggestions to get this working through wireless camera? Here are my settings:
Source Type: Remote
Function: Monitor
Enabled: Yes
Remote Protocol: HTTP
Remote Method: Simple
Remote Host Name: Camera's IP
Remote Host Port: 80
Capture Width (pixels): 320
Capture Height (pixels): 240
Preserve Aspect Ratio: No
Orientation: Normal
THANKS!
