SORRY USE THIS SECOND ONE
well here's the script developed by Normando and base from:
http://www.zoneminder.com/forums/viewto ... ht=vivotek
for install in ubuntu 10.04 rename it as VivotekSd7151.pm and put in in:
/usr/share/perl5/ZoneMinder/Control
as the complete path looks like : /usr/share/perl5/ZoneMinder/Control/VivotekSd7151.pm
for different distro copy it in your "control" perl modules.
# This module contains the implementation of the Vivotek SD7151 protocol
# It is easy to adapt to other Vivotek cameras. I have found a lot of commands with Wireshark
# This protocol get some info from the camera through receiveCmd function.
# Implement a pseudo diagonal movement
# Where go "presetClear" function from php code?
# Any improve is welcome, and please share it
# Normando Hall nhall[AT]unixlan[DOT]com[DOT]ar
package ZoneMinder::Control::VivotekSD7151;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
# Vivotek SD7151 Control Protocol
use Time::HiRes qw( usleep );
sub new
my $class = shift;
my $id = shift;
bless( $self, $class );
srand( time() );
return $self;
our $AUTOLOAD;
sub AUTOLOAD
my $self = shift;
my $name = $AUTOLOAD;
$name =~ s/.*://;
if ( exists($self->{$name}) )
return( $self->{$name} );
sub open
my $self = shift;
$self->loadMonitor();
use LWP::UserAgent;
$self->{state} = 'open';
sub close
my $self = shift;
$self->{state} = 'closed';
sub printMsg
my $self = shift;
my $msg = shift;
my $msg_len = length($msg);
sub sendCmd
my $self = shift;
my $cmd = shift;
my $result = undef;
printMsg( $cmd, "Tx" );
#print( "http://$address/$cmd\n" );
if ( $res->is_success )
$result = !undef;
else
return( $result );
sub receiveCmd
my $self = shift;
my $cmd = shift;
my $result = undef;
printMsg( $cmd, "Rx" );
my $content = $res->content();
$result = $content;
else
return( $result );
sub reset
my $self = shift;
Debug( "Camera Reset" );
my $cmd = "/cgi-bin/admin/setparam.cgi?System_Reset=3";
$self->sendCmd( $cmd );
sub moveMap
my $self = shift;
my $params = shift;
my $xcoord = $self->getParam( $params, 'xcoord' );
my $ycoord = $self->getParam( $params, 'ycoord' );
my $imagewidth = $self->{Monitor}->{Width};
my $imageheight = $self->{Monitor}->{Height};
Debug( "Move Map to $xcoord,$ycoord at $imagewidth/$imageheight" );
if ( $imagewidth == "640" )
$xcoord = $xcoord/2;
$ycoord = $ycoord/2;
my $cmd = "/cgi-bin/camctrl/camctrl.cgi?cam1&x=$xcoord&y=$ycoord";
sub moveRelUp
my $self = shift;
my $params = shift;
my $tiltspeed = $self->getParam( $params, 'tiltspeed' );
Debug( "Move Up - Speed $tiltspeed" );
my $cmd = "/cgi-bin/camctrl/camctrl.cgi?move=up&speedtilt=$tiltspeed";
sub moveRelDown
my $self = shift;
my $params = shift;
Debug( "Move Down - Speed $tiltspeed" );
my $cmd = "/cgi-bin/camctrl/camctrl.cgi?move=down&speedtilt=$tiltspeed";
sub moveRelLeft
my $self = shift;
my $params = shift;
my $panspeed = $self->getParam( $params, 'panspeed' );
Debug( "Move Left - Speed $panspeed" );
my $cmd = "/cgi-bin/camctrl/camctrl.cgi?move=left&speedpan=$panspeed";
sub moveRelRight
my $self = shift;
my $params = shift;
Debug( "Move Right - Speed $panspeed" );
my $cmd = "/cgi-bin/camctrl/camctrl.cgi?move=right&speedpan=$panspeed";
sub moveRelUpRight
my $self = shift;
my $params = shift;
Debug( "Move Up/Right - Speed $tiltspeed/$panspeed" );
sub moveRelUpLeft
my $self = shift;
my $params = shift;
Debug( "Step Up/Left - Speed $tiltspeed/$panspeed" );
my $cmd = "/cgi-bin/camctrl.cgi?move=left&speedpan=$panspeed";
my $cmd = "/cgi-bin/camctrl.cgi?move=up&speedtilt=$tiltspeed";
sub moveRelDownRight
my $self = shift;
my $params = shift;
Debug( "Step Down/Right - Speed $tiltspeed/$panspeed" );
sub moveRelDownLeft
my $self = shift;
my $params = shift;
Debug( "Step Down/Left - Speed $tiltspeed/$panspeed" );
# test di zoom della camera
#sub zoomtele
# my $self = shift;
# my $params = shift;
# my $panspeed = $self->getParam( $params, 'panspeed' );
# my $tiltspeed = $self->getParam( $params, 'tiltspeed' );
# Debug( "Step Down/Left - Speed $tiltspeed/$panspeed" );
# my $cmd = "/cgi-bin/camctrl/camctrl.cgi?zoom=tele&speedtele=$telespeed";
# $self->sendCmd( $cmd );
# my $cmd = "/cgi-bin/camctrl/camctrl.cgi?move=down&speedtilt=$tiltspeed";
#fine del test
sub whiteAuto
my $self = shift;
Debug( "White Auto" );
my $cmd = "/cgi-bin/admin/setparam.cgi?Video_Whitebalance=0";
sub whiteMan
my $self = shift;
Debug( "White Man" );
my $cmd = "/cgi-bin/admin/setparam.cgi?Video_Whitebalance=2";
sub In
my $self = shift;
Debug( "White In" );
my $cmd = "/cgi-bin/admin/setparam.cgi?Video_Whitebalance=1";
sub Out
my $self = shift;
Debug( "White Out" );
my $cmd = "/cgi-bin/admin/setparam.cgi?Video_Whitebalance=3";
sub presetClear
my $self = shift;
my $params = shift;
my $preset = ( $preset - 1 );
Debug( "Clear Preset $preset" );
my $cmd = "/cgi-bin/admin/preset.cgi?delpos=$preset&Submit=Delete";
sub presetSet
my $self = shift;
my $params = shift;
my $cmd = "/cgi-bin/admin/getparam.cgi?camctrl_axisx";
my $rx = $self->receiveCmd( $cmd );
my ($axisx) = $rx =~ /([-0-9]+)/;
my $cmd = "/cgi-bin/admin/getparam.cgi?camctrl_axisy";
my ($axisy) = $rx =~ /([-0-9]+)/;
Debug( "Set Preset $preset at $axisx and $axisy" );
my $cmd = "/cgi-bin/admin/setparam.cgi?camctrl_presetname_$preset=$preset&camctrl_presetpan_$preset=$axisx&camctrl_presettilt_$
sub presetGoto
my $self = shift;
my $params = shift;
my $cmd = "/cgi-bin/recall.cgi?recall=$preset";
sub presetHome
my $self = shift;
Debug( "Home Preset" );
my $cmd = "/cgi-bin/camctrl/camctrl.cgi?move=home";
1;
__END__
Under control tab of your monitor:
Controllable: check
Control Device: none
Control Address: the camera IP, or user:pass@camera_ip
Return Location: Home
and follow the same instruction gave from normando at:
remenber to change the name from Vivotek PT7135 to: Vivotek SD7151
the script work pretty fine, and can controlo up, down, lef, right, return to home, no zoom, no focus, no mapped areas. we will get you up to date in case of new development.
many many thanks to normando for his script.
Remember also to donate to zoneminder.
ilios
