USB camera Logitech QuickCam Pro 4000 help
gazoo
Post by gazoo »
I'm curious to see what I need to get this camera up and working. I plugged it in, nothing happened. I specified local and /dev/video0 but it just won't work. Is there a driver involved? Forgive my n00bness on this.
What's really strange is that I pretty much had the IP cameras up and running within an hour, which I thought would be harder. Seems the other way around, USB is more difficult.
gazoo
Post by gazoo »
This is what I get:
zmu -d /dev/video0 -q -v
Video Capabilities
Name: Logitech QuickCam Pro 4000
Type: 1
Can capture
Video Channels: 1
Audio Channels: 1
Maximum Width: 640
Maximum Height: 480
Minimum Width: 160
Minimum Height: 120
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 240
Picture Attributes
Palette: 15 - YUV 4:2:0 Planar
Colour Depth: 24
Brightness: 32256
Hue: 65535
Colour :32441
Contrast: 32768
Whiteness: 49152
Channel 0 Attributes
Channel: 0
Flags: 0
Type: 2 - Camera
Format: 49150 - Unknown
The format is the one that is stumping me. I don't know if that's what's keeping it from working. Format 49150 doesn't correspond to any in the ZM list like NTSC or PAL or etc...
I used 640x480, 320x240, changed to pal, nstc, etc. but no luck.
gazoo
Post by gazoo »
Solved it's a permissions issue with /dev/video0
