Source listings still in red
Keiichi
Post by Keiichi »
So having set everything up I find that Function is Properly orange but all the device paths are still red. All the equipment is known good, I've increased the shared memory to ZoneMinder up to somewhere around 330000000 and tried any of the Device formats that might work under both of the capture methods. Has anyone else encountered this issue?
Keiichi
Post by Keiichi »
No one? Nothing.
jfkastner
Post by jfkastner »
pls post some logs here, w/o it's impossible to give you any helpful tips!
ClarkJeff
Post by ClarkJeff »
I had similar issues and this fixed my problem:
sudo adduser www-data video
Painter
Post by Painter »
In my case using a quad kodicom 4400r card i have to select only compatible "Capture palette" and Capture width & height pixels inside the Source properties of the camera setup.
Settings that work for me are RGB555 or gray and capture resolution 320X240, 352X288 & 720x576.
