Page 1 of 1
Source listings still in red
Posted: Wed Dec 02, 2009 7:14 pm
by Keiichi
So having set everything up I find that Function is Properly orange but all the device paths are still red. All the equipment is known good, I've increased the shared memory to ZoneMinder up to somewhere around 330000000 and tried any of the Device formats that might work under both of the capture methods. Has anyone else encountered this issue?
Posted: Thu Dec 03, 2009 4:00 pm
by Keiichi
No one? Nothing.
Posted: Thu Dec 03, 2009 10:32 pm
by jfkastner
pls post some logs here, w/o it's impossible to give you any helpful tips!
Posted: Sat Dec 05, 2009 6:46 am
by ClarkJeff
I had similar issues and this fixed my problem:
sudo adduser www-data video
Posted: Mon Dec 07, 2009 10:17 am
by Painter
In my case using a quad kodicom 4400r card i have to select only compatible "Capture palette" and Capture width & height pixels inside the Source properties of the camera setup.
Settings that work for me are RGB555 or gray and capture resolution 320X240, 352X288 & 720x576.
