Thanks for a superb product in Zoneminder.
Ive been using it for about 2 months now. got it running on ubuntu 8.04. everythings running wonderfully on monitor mode. Ive attached a 1 TB HD for storage purposes and sym linked the ../zm/temp ; images & events folders to this new hdrive. Ive double checked permissions on the 1TB drive and have it set to www-data as owner. When I set the cameras to mocord, ZM writes events to the folders as the folder fills up with images. I cannot however play them back. Also, when trying to configure the zone - theres no image being loaded on the screen where you gotta define the zone area. Im attaching a part of the error log from apache. thanks for any help!
ray (\n 'file' => '/var/www/html/zm/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /var/www/html/zm/temp/zms-172740s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/var/www/html/zm/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/var/www/html/zm/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.0.154/zm/index.php?view=watch&mid=33
[Mon Dec 07 08:18:14 2009] [error] [client 192.168.0.159] socket_sendto( /var/www/html/zm/temp/zms-348678s.sock ) failed: No such file or directory, referer: http://192.168.0.154/zm/index.php?view=watch&mid=47
[Mon Dec 07 08:18:14 2009] [error] [client 192.168.0.159] array (\n 0 => \n array (\n 'file' => '/var/www/html/zm/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /var/www/html/zm/temp/zms-348678s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/var/www/html/zm/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/var/www/html/zm/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.0.154/zm/index.php?view=watch&mid=47
[Mon Dec 07 11:15:35 2009] [error] [client 192.168.0.156] File does not exist: /var/www/html/zm/function.mysql-pconnect, referer: http://192.168.0.154/zm/index.php?
