I used a local web cam that work correctly under vlc and of course zoneminder. My webcam is configured as Modetect and with this parameter :
Conf de la web cam philips :
Name webcam_video0
source type local
Function Modetect
Enabled = X
linked monitors = webcam_video0
max fps = nothing
alarm max fps = nothing
ref image blend %ge = 7
triggers = none available
/dev/video0
video for linux version 2
device channel : 0
device format : Undefined
Capture Palette YUV420
capture width 352
capture Height 288
The system is ubuntu 9.10 with apache2. Installation of this package are performed with apt-get install
I have some trouble with event.
Everythink works fine but if I have an event like somebody says hello to the webcam, I have no events, but I have some error under /var/message/apache2/error.log :
[Sun Dec 13 23:43:37 2009] [error] [client 192.168.1.6] socket_sendto( /tmp/zms-682931s.sock ) failed: No such file or directory, referer: https://nas/zm/index.php?view=event&eid ... 1=1&page=1
[Sun Dec 13 23:43:37 2009] [error] [client 192.168.1.6] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 51,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-682931s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: https://nas/zm/index.php?view=event&eid ... 1=1&page=1
I do some modification about script alias ( this comming form another post on this forum :
http://www.zoneminder.com/forums/viewtopic.php?p=57753 and
http://www.zoneminder.com/forums/viewto ... s+captured )
But the problem is not solved.
If I restart zoneminder I always have 1 event but it is empty 0 seconds, then i removed this event and after that I try to generate a new event like says hello to the webcam, nothing append and I have the error in apache (error above).
If I icheck in /usr/share/zoneminder/events/1/51 I have many pictures, and I have the pictures when I say hello to the webcam.
What I do wrong ?
or what I missed
fil
