Pertinent Info:
System:Karmic Ubuntu 9.10
kernel:2.6.31-16-generic
Zoneminder Version:1.24.1
Apache Version:2.2.12
Perl Version:5.10.0-24
Wxcam version:1.0.4-1
uvcdynctrl 0.2
uvcdynctrl -c
Raw bits per pixel
Disable video processing
LED1 Frequency
LED1 Mode
Pan/tilt Reset
Focus (absolute)
Tilt Reset
Pan Reset
Tilt (relative)
Pan (relative)
Exposure, Auto Priority
Exposure (Absolute)
Exposure, Auto
Backlight Compensation
Sharpness
Power Line Frequency
Gain
White Balance Temperature, Auto
Saturation
Contrast
Brightness
Can't connect: No such file or directory at /usr/share/perl5/ZoneMinder/Debug.pm line 349
ZoneMinder::Debug::Fatal('Can\'t connect: No such file or directory') called at /usr/bin/zmcontrol.pl line 153
[Sat Dec 19 17:03:39 2009] [error] [client ::1] /usr/bin/zmcontrol.pl --panspeed=15 --autostop --command=moveConRight --id=10=>, referer: http://localhost/?view=watch&mid=10
[Sat Dec 19 17:03:39 2009] [error] [client ::1] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/control.php',\n 'line' => 1000,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => '/usr/bin/zmcontrol.pl --panspeed=15 --autostop --command=moveConRight --id=10=>',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/control.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://localhost/?view=watch&mid=10
Hopefully this is enough for somebody to start me on the road. I think despite what I have read I have a fundamental misunderstanding of how libwebcam, uvcvideo, and uvcdynctrl (maybe PTZ?) can work with zoneminder via a control module. The camera does work to produce an image though and the combination with mysql is very powerful. I guess I should add I have had no success trying to Motion working with controls either.
