Hello everyone,
I need a surveillance system at home. I have CentOS on my home laptop. I am rather a novice, I use CentOS but the administration part is largely done by system administrators at work. So I want to know if this is doable by a novice or should I not even try? There seems to be no mysql ("which mysql" yields nothing), and there is no libjpeg.a in the lib directory. I don't even have a webcam yet.
Thank you,
Sally
Zone minder for linux non-expert
yeah, that's why i am hesitant - don't want to screw up/lose other stuff on the laptop. i do have root permission but use it very cautiously and hesitantly.
i was reading the wiki pages at http://www.zoneminder.com/wiki/index.ph ... der_1.24.2 , it seems i have to run these as root. are these likely to cause any serious damage?
if all this is too complicated, is there any simple standalone surveillance camera that i can buy that captures images only when motion is detected and stores it in a memory card readable by my laptop?
zoneminder should not be run on a laptop being used as a laptop in most situations. It is best to run zoneminder on an always on desktop/server (as generally most people what 24/7survaliance) but as its cpu and disk requirements can vary it would cause interference or be interfered with a user on their laptop using it most likely. You can buy atom micro machines for $100-200 that would work far better for ZM.
