Page 1 of 1
After upgrading gentoo - no image in zm - libavutil.so.49
Posted: Wed Dec 23, 2009 7:43 pm
by christophe_y2k
hello !
after upgrading my gentoo server
no image in ZM V1.23.3
zm run fine but when i wanna to see a cam, broken link no image
but that say video - 2.67 fps and that detect alert but haven't got any image
i precise all work fine before upgrade my gentoo
error in apache
/var/www/localhost/cgi-bin/nph-zms: error while loading libraries: libavutil.so.49: cannot open shared object file: No such file or directory,
i reinstall ffmpeg with no success
haven't got: libavutil.so.49
but i have: libavutil.so.50
new version?
any idea?
Joyeuse fêtes de fin d'année
workaround
Posted: Wed Dec 23, 2009 8:42 pm
by christophe_y2k
i create a symbolic link to livavutil.so.50.3.0 present on my system in /usr/lib64 to libavutil.so.49
that works fine but this is a piece of scotch
if anybody have better idea !!!
special thanks to Philip Coombes for this work
now i'm an happy paypal contributor
:D
Posted: Fri Dec 25, 2009 7:08 am
by cordel
You would have to rebuild ZM and honestly I'm surprised that simlinking worked since the differences between 4.9 and 5.0 are tremendous.
Matter of fact you might just leave it be as I'm not sure that 1.23.3 can build on the newer ffmpeg without patching.
Posted: Wed Dec 30, 2009 10:51 am
by christophe_y2k
thanks for your reply...
i try to rebuild zm with no succes (when i say rebuild i use the installer from gentoo "emerge zoneminder" not compiling from source)
the latest version is not released for gentoo .
i try to compile from source the latest version on another computer ....
i can't try on my product server
now i know i c'ant upgrade my gentoo "in security" ...
Posted: Sat Jan 23, 2010 7:58 pm
by mastertheknife
After doing major updates with gentoo, its sometimes necessary to rebuild few things
just run: revdep-rebuild and it should do the job.
Re: After upgrading gentoo - no image in zm - libavutil.so.4
Posted: Fri Feb 19, 2010 8:00 pm
by braindead0
christophe_y2k wrote:hello !
error in apache
new version?
any idea?
Re-emerge apache, should take care of that.
