axis streaming results in periodic corrupted images
Posted: Thu Dec 31, 2009 3:50 am
I've setup up my Axis cameras for streaming (Axis 207) using the ffmpeg source. One caveat is that my server uses a wireless connection due to the requirement that it also serves a dual role as an HTPC, and thus could not be optimally located for a wired connection.
The path to the camera is through rtsp which should be TCP and should technically compensate for network errors. However, I see the following corruption roughly once every hour.
Any idea if this is due to the camera, ffmpeg, or the network? I had the same camera under the same setup working fine without this type of corruption when it was configured for mjpeg.[/img]
