Page 1 of 1
Monitor Video Source
Posted: Fri Jan 08, 2010 3:22 am
by jlross
I have been running ZoneMinder 1.22.x with Fedora 8 for quite some time. I decided to upgrade to Fedora 11 to get the newest version of ZoneMinder. I have a 4 port video card with 2 cameras. I previously had the source of these 2 cameras as /dev/video0 channel 0 and /dev/video1 channel 0.
After I upgraded, I set up the cameras the same but no combination I use will show the cameras. The source stays red with no video. There are 3 devices showing (dev/video0-dev/video3).
I don't understand why the exact same source settings aren't working. How can I determine where the video is coming in?
Posted: Fri Jan 08, 2010 5:07 pm
by JohnnyLaww
Well, for us to be able to figure out whats not working, we need a little more info. If I had to guess, my money is on your OS not correctly detecting your video capture board.
1. Which Video Capture board are you using? (ie, brand, model #)
1a. Post the ouput of
dmesg | grep bttv
2. Post the output of
lspci
3. Post your log files so we can see whats going on with ZM and your OS.
John
Posted: Fri Jan 08, 2010 6:34 pm
by jlross
1. Bluecherry PV-149
2. dmesg | grep bttv
bttv: driver version 0.9.17 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
bttv 0000:03:08.0: PCI INT A -> Link[LNKA] -> GSI 9 (level, low) -> IRQ 9
bttv0: Bt878 (rev 17) at 0000:03:08.0, irq: 9, latency: 64, mmio: 0x20000000
bttv0: detected: Provideo PV150A-1 [card=98], PCI subsystem ID is aa00:1460
bttv0: using: ProVideo PV150 [card=98,autodetected]
IRQ 9/bttv0: IRQF_DISABLED is not guaranteed on shared IRQs
bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv0: tuner absent
bttv0: registered device video0
bttv0: registered device vbi0
bttv0: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (1).
bttv 0000:03:09.0: PCI INT A -> Link[LNKB] -> GSI 10 (level, low) -> IRQ 10
bttv1: Bt878 (rev 17) at 0000:03:09.0, irq: 10, latency: 64, mmio: 0x20002000
bttv1: detected: Provideo PV150A-2 [card=98], PCI subsystem ID is aa01:1461
bttv1: using: ProVideo PV150 [card=98,autodetected]
IRQ 10/bttv1: IRQF_DISABLED is not guaranteed on shared IRQs
bttv1: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv1: tuner absent
bttv1: registered device video1
bttv1: registered device vbi1
bttv1: PLL: 28636363 => 35468950 ..<6>iTCO_vendor_support: vendor-support=0
bttv: Bt8xx card found (2).
bttv 0000:03:0a.0: PCI INT A -> Link[LNKC] -> GSI 5 (level, low) -> IRQ 5
bttv2: Bt878 (rev 17) at 0000:03:0a.0, irq: 5, latency: 64, mmio: 0x20004000
bttv2: detected: Provideo PV150A-3 [card=98], PCI subsystem ID is aa02:1462
bttv2: using: ProVideo PV150 [card=98,autodetected]
IRQ 5/bttv2: IRQF_DISABLED is not guaranteed on shared IRQs
bttv2: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv2: tuner absent
bttv2: registered device video2
bttv2: registered device vbi2
bttv2: PLL: 28636363 => 35468950 ..<6>iTCO_wdt: Intel TCO WatchDog Timer Driver v1.05
bttv: Bt8xx card found (3).
bttv 0000:03:0b.0: PCI INT A -> Link[LNKD] -> GSI 11 (level, low) -> IRQ 11
bttv3: Bt878 (rev 17) at 0000:03:0b.0, irq: 11, latency: 64, mmio: 0x20006000
bttv3: detected: Provideo PV150A-4 [card=98], PCI subsystem ID is aa03:1463
bttv3: using: ProVideo PV150 [card=98,autodetected]
IRQ 11/bttv3: IRQF_DISABLED is not guaranteed on shared IRQs
bttv3: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv3: tuner absent
bttv3: registered device video3
bttv3: registered device vbi3
bttv3: PLL: 28636363 => 35468950 .. ok
3. lspci
00:00.0 Host bridge: Intel Corporation 82820 820 (Camino) Chipset Host Bridge (MCH) (rev 04)
00:01.0 PCI bridge: Intel Corporation 82820 820 (Camino) Chipset AGP Bridge (rev 04)
00:1e.0 PCI bridge: Intel Corporation 82801AA PCI Bridge (rev 02)
00:1f.0 ISA bridge: Intel Corporation 82801AA ISA Bridge (LPC) (rev 02)
00:1f.1 IDE interface: Intel Corporation 82801AA IDE Controller (rev 02)
00:1f.2 USB Controller: Intel Corporation 82801AA USB Controller (rev 02)
00:1f.3 SMBus: Intel Corporation 82801AA SMBus Controller (rev 02)
00:1f.5 Multimedia audio controller: Intel Corporation 82801AA AC'97 Audio Controller (rev 02)
01:00.0 VGA compatible controller: nVidia Corporation NV5M64 [RIVA TNT2 Model 64/Model 64 Pro] (rev 15)
02:0b.0 PCI bridge: Hint Corp HB6 Universal PCI-PCI bridge (non-transparent mode) (rev 11)
02:0c.0 Ethernet controller: 3Com Corporation 3c905C-TX/TX-M [Tornado] (rev 78)
03:08.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
03:08.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
03:09.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
03:09.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
03:0a.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
03:0a.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
03:0b.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
03:0b.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
4. I think this is the section of the log you want. Looks like there is an error:
Jan 8 12:38:42 zm kernel: usbcore: registered new device driver usb
Jan 8 12:38:42 zm kernel: PCI: Using ACPI for IRQ routing
Jan 8 12:38:42 zm kernel: pci 0000:03:08.0: BAR 0: can't allocate resource
Jan 8 12:38:42 zm kernel: pci 0000:03:08.1: BAR 0: can't allocate resource
Jan 8 12:38:42 zm kernel: pci 0000:03:09.0: BAR 0: can't allocate resource
Jan 8 12:38:42 zm kernel: pci 0000:03:09.1: BAR 0: can't allocate resource
Jan 8 12:38:42 zm kernel: pci 0000:03:0a.0: BAR 0: can't allocate resource
Jan 8 12:38:42 zm kernel: pci 0000:03:0a.1: BAR 0: can't allocate resource
Jan 8 12:38:42 zm kernel: pci 0000:03:0b.0: BAR 0: can't allocate resource
Jan 8 12:38:42 zm kernel: pci 0000:03:0b.1: BAR 0: can't allocate resource
Posted: Sat Jan 09, 2010 4:00 am
by JohnnyLaww
Okay, you are absolutely right there is an issue with your card not being initialized properly.
Which kernel are you running? To find out you can run
uname -r
This shouldn't be an issue but let's not overlook anything.
Edit:
You might also try following this thread: http://www.zoneminder.com/forums/viewtopic.php?t=15044
Posted: Sat Jan 09, 2010 3:28 pm
by jlross
I upgraded to Fedora 12 and am having exactly the same problem. The kernel with this version is 2.6.31.9-174.fc12.i686.
I have used this computer for several years with Fedora 8 and ZM but wonder if the resources are too minimal for Fedora 12. It's a P800 with 384 megs of memory. I hope this isn't the problem but if it is I'll have to downgrade back to my old setup and use that. Hopefully another solution can be found.
