change camera Function via Crontab ?
DaGeek
Post by DaGeek »
Hi All,
I have a few ZM's in production, but have never looked into how to change the
mode of a camera/monitor in ZM via cronab...
i.e. I have a camera in 'Record' mode but this just eats up my HDD space, so
I would like the cam to run in 'Record' mode during say 0900-1700 and the switch to 'modect' during the 1700-0900 hours.
The easiest way to do this i guess would be via a crontab, but what would the command be that i need to change the cam from one mode to the other from the CLI ?
Thank You all for any comments/suggestions.
If I can get it working I might even make a web GUI change and add it as a patch to the ZM Code.
clipo
Post by clipo »
Did you get any further with this function.
jdhar
Post by jdhar »
eyeZm, Native iPhone App for ZoneMinder: http://www.eyezm.com
Version 1.3 now available on iTunes, introduces Montage view, HTTPS/SSL support and H264 native streaming!
Subscribe to RSS feed for updates: http://www.eyezm.com/rssfeed.xml
clipo
Post by clipo »
Thats just what I was after,
thanks
