Page 1 of 1
Wireless internet conflict with 2.4ghz wireless cameras
Posted: Mon Jan 25, 2010 11:21 pm
by Papa Oso
I'm using 4 2.4ghz wireless cameras. The problem is when the cameras are working the wireless Internet not. My wireless router is a linksyst wrt54g v2 with tomato firmware. Any suggestion?
Posted: Mon Jan 25, 2010 11:33 pm
by kingofkya
switch to a A frequency router 5.8ghz new cameras , or get ipcams
another thing that MIGHT work is to move fequency of the b/g router to 1 or 6
Posted: Thu Jan 28, 2010 3:38 am
by allanE
You might want to consider a second router to handle the cameras. This would unburden the main ( internet ) router. Just set cameras and second router to any freq not used by the main router and it will end the conflict. Cameras tend to be bandwidth hogs
Allan
Posted: Thu Jul 08, 2010 4:00 pm
by rynmackz
I don't know what is the real problem. But I think something wrong with your wireless device so you can't connect. Try to check your router and maybe you need to reset it just like my friend did.
