"Delete & Prev" takes a wrong turn...
lazyleopard
Post by lazyleopard »
Using zm 1.18.1, I've got a couple of monitors set up, and a couple of separate users. The users are set up so that one can "see"
one monitor, and the other can see the other. If I hit "Delete & Prev" on the event viewing window then the next event viewed
is the next in sequence, whether or not it is from a monitor that user is supposed to be able to see. Also, the links under the view
(Nex, Prev, etc.) vanish after they're used the first time. I've seen this using Mozilla 1.6 and Mozilla FireFox.
zoneminder
Site Admin
Re: "Delete & Prev" takes a wrong turn...
Post by zoneminder »
Hi Rick,
The disappearing links problem has been reported and will be fixed in the next release. The other issue you mentioned about lack of monitor partitioning I'll fix now and also include that.
Cheers,
Phil,
