zmcontrol.pl - Can't connect: Permission denied
fechebsd
Post by fechebsd »
Hi, sorry for my bad english.
i have a jmk up010 ip camera, and i follow this configuration: http://www.zoneminder.com/forums/viewto ... 561c147ce1
I only have problem with PTZ control.
in my zmcontrol.log i see:
01/27/10 15:19:13.506340 zmcontrol[8711].INF [Starting control server 1/jmkup10]
01/27/10 15:19:13.534749 zmcontrol[8714].INF [Control server 1/jmkup10 starting at 10/01/27 15:19:13]
01/27/10 15:19:23.550759 zmcontrol[8711].FAT [Can't connect: Permission denied]
if i execute zmcontrol.pl from shell:
[root@localhost ~]# /usr/bin/zmcontrol.pl --id=1 --command=moveConUp
Can't connect: Connection refused at /usr/lib/perl5/vendor_perl/5.10.0/ZoneMinder/Debug.pm line 349
        ZoneMinder::Debug::Fatal('Can\'t connect: Connection refused') called at /usr/bin/zmcontrol.pl line 154
[root@localhost ~]#
thank very much
bye
TechGuy
Re: zmcontrol.pl - Can't connect: Permission denied
Post by TechGuy »
Perhaps this is a silly question, but did you try connecting to the camera's tcp\udp port for the PTZ? Perhaps the ports are inaccessible either because they are not turned on, on the camera, or because of firewall rules blocking them.
