I am having a problem viewing events that I can't seem to find any references to anything similar. My specs are below but I have Zoneminder up and running and while viewing events captured under modect I am having an issue with the playback.
The image buffer is 300 frames, pre-event is set to 150 frames (using 30 FPS) and the post-event is set to 300 frames.
Playback of the event is fine (ie shown real time) during the pre-event buffer but once it reaches the post-event frame count playback appears to be faster maybe something like 15 FPS.
The rate display in the event viewing window still show 1x during the entire playback but the post event is clearly faster or frames are missing.
The max and alarm FPS are not defined.
Any ideas on what this could be?
Thanks in advance!!
Zoneminder 1.24.2 compiled manually on Ubuntu 9.10 with the mmap option enabled. Core 2 Quad 2.4, 4GB RAM
