deleting old images and events
adub
Post by adub »
does anyone have any insight to setup an automatic delete of events and/or images that are stored on the hard drive??
I seen a post for events from the database. Was wondering if anyone had tested this script.
Thanks to all who reply
adub
on the above
Post by adub »
also when you delete events will it delete the images as well
From what I recall I dont think it does but maybe it does I am unsure the script worked with the mysql database
Paranoid
Post by Paranoid »
zmaudit.pl performs this task. It will delete images/events from the hard drive that dont have a corresponding entry in the database and vice-versa.
You can set zmaudit to run periodically via the options menu.
mastertheknife
Post by mastertheknife »
Use filters. You can create your own or use the PurgeWhenFull filter or modify it and save under a new name.
Then you need to enable run in background..
kevin_robson
Post by kevin_robson »
Also check whether ZM_OPT_FAST_DELETE is set in options.
If it is then the diskspace will not be reclaimed until you restart zm, which probably isn't what you want.
Paranoid
Post by Paranoid »
kevin_robson wrote:Also check whether ZM_OPT_FAST_DELETE is set in options.
zmaudit will reclaim the disk space without restarting zm
