error on device
marculin
error on device
Post by marculin »
Hello.
I had a zoneminder 1.23.
I've deleted database and installed rpm of version 1.24.2 on SUSE 11.1
I have created a new database.
When I open zoneminder I have a source /dev/video0 which is red and in log I have this error
Feb 13 00:23:57 xxxx zmc_dvideo0[5520]: ERR [Capture failure for frame 0: Device or resource busy]
Feb 13 00:23:57 xxxx zmc_dvideo0[5520]: ERR [Failed to prime capture of initial monitor]
Feb 13 00:23:57 xxxx zmdc[5464]: ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
any idea? Thank you
ipcs -l
------ Shared Memory Limits --------
max number of segments = 4096
max seg size (kbytes) = 250000
max total shared memory (kbytes) = 1024000000
min seg size (bytes) = 1
------ Semaphore Limits --------
max number of arrays = 1024
max semaphores per array = 250
max semaphores system wide = 256000
max ops per semop call = 32
semaphore max value = 32767
------ Messages: Limits --------
max queues system wide = 498
max size of message (bytes) = 65536
default max size of queue (bytes) = 65536
[/code]
