[FIX] ZM 1.24.2: Marking a monitor from a restricted user
mastertheknife
Post by mastertheknife »
How to reproduce:
1) Create a user with monitors edit privilege, but restrict him to a monitor or a few.
2) Login with that user and go to console page (main page)
3) Try to mark a monitor to edit it or delete it. You can't mark it unless you remove the monitor restrictions (unselect all monitors with Ctrl) for that user.
Bug was found by j1mw3b, see here for more information: http://www.zoneminder.com/forums/viewtopic.php?p=59562
In file skins/classic/views/console.php, edit the following, which starts at around line 333 (May vary from installation to installation)
Change it from:
<td class="colMark"><input type="checkbox" name="markMids[]" value="<?= $monitor['Id'] ?>" onclick="setButtonStates( this )"<?php if ( !canEdit( 'Monitors' ) || $user['MonitorIds'] ) {?> disabled="disabled"<?php } ?>/></td>
To:
<td class="colMark"><input type="checkbox" name="markMids[]" value="<?= $monitor['Id'] ?>" onclick="setButtonStates( this )"<?php if ( !canEdit( 'Monitors' ) ) {?> disabled="disabled"<?php } ?>/></td>
mastertheknife.
