BUG: zma exits with large values of Pre Event Image Count
Posted: Tue Feb 23, 2010 9:05 pm
When "Pre Event Image Count" is greater than about 170 zma will exit abnormally.
I've tracked it down to Event::AddFrames zm_event.cpp
With large values of n_frames the sql buffer fills up (it doesn't overflow) and mysql_query ends up being called with a malformed sql statement. This results in an error and zma exits.
The solution may be to save the frames in smaller numbers. An example of how this could be done is shown below:
The above code is untested (I haven't even tried to compile it).
void Event::AddFrames( int n_frames, Image **images, struct timeval **timestamps )
static char sql[BUFSIZ];
strncpy( sql, "insert into Frames ( EventId, FrameId, TimeStamp, Delta ) values ", BUFSIZ );
for ( int i = 0; i < n_frames; i++ )
frames++;
static char event_file[PATH_MAX];
snprintf( event_file, sizeof(event_file), capture_file_format, path, frames );
Debug( 1, "Writing pre-capture frame %d", frames );
WriteFrameImage( images[i], *(timestamps[i]), event_file );
struct DeltaTimeval delta_time;
DELTA_TIMEVAL( delta_time, *(timestamps[i]), start_time, DT_PREC_2 );
int sql_len = strlen(sql);
snprintf( sql+sql_len, sizeof(sql)-sql_len, "( %d, %d, from_unixtime(%ld), %s%ld.%02ld ), ", id, frames, timestamps[i]->tv_sec, delta_time.positive?"":"-", delta_time.sec, delta_time.fsec );
Debug( 1, "Adding %d frames to DB", n_frames );
*(sql+strlen(sql)-2) = '\0';
if ( mysql_query( &dbconn, sql ) )
Error( "Can't insert frames: %s", mysql_error( &dbconn ) );
exit( mysql_errno( &dbconn ) );
last_db_frame = frames;
frames++;
if ( i && i % 100 == 0 )
Debug( 1, "Adding %d/%d frames to DB", i, n_frames );
if( (n_frames - 1) % 100 )
