Page 1 of 1
Edimax IC-3010 not displaying static images
Posted: Fri Feb 26, 2010 5:51 pm
by matt91
I've just got an Edimax IC-3010 and it is working and I can access http://192.168.2.3/snapshot.jpg from the network without authentication.
For the ZM monitor i have set it as Remove with 1FPS, HTTP protocol, simple, host name 192.168.2.3, port 80, remote host path /snapshot.jpt and the dimensions to 640x480. Everything else is left as default. Zoneminder will not display the camera (just the usual broken image icon in place).
I do not understand why it isn't working because I have tested ZM using an online webcam which has worked for a few days without hitch.
I've setup guest access at http://entr.co.uk/zoneminder with guest/guest if that helps.
Thanks, Matt.
Posted: Fri Feb 26, 2010 5:57 pm
by jameswilson
id suggest your running into shared mem problems. Have a look at your log and if so see the faw regarding cannot shmget
Posted: Fri Feb 26, 2010 6:24 pm
by matt91
Thank you for that help. The logs confirmed the shared memory problem and I've increased it. Explains why the other cam was working with a lower resolution.
Matt.
Posted: Fri Feb 26, 2010 9:08 pm
by johnnytolengo
I check your fps and you are getting aroud 15 fps like me with .jpg is not enought?
Regards
J.
Posted: Fri Feb 26, 2010 11:04 pm
by matt91
No, the speed with .jpg is more than good enough. May try restricting it to a lower fps as it is hampering the cpu a little (though nothing to really complain about).
The camera is not much use in low light though, thought it would cope better seeing as theirs a street-light outside the house.
Posted: Sat Feb 27, 2010 8:01 am
by johnnytolengo
ZM can not reduce the fps sent from your camera.
J.
Posted: Tue Mar 02, 2010 9:17 am
by dyu
Yea that part sucks. My IC-3010 cams are blind at night.
Have you tried buying standalone IR illuminators and projecting it to the cam's view?
I'm not sure if that works but I'm contemplating on trying it.
Posted: Wed Mar 03, 2010 10:28 pm
by matt91
Just tried shining an LED torch (not sure if it has and IR coming from it or not) towards the camera and I did notice a bit of improvement in the picture, more definition in the cars and i could see the edges of the road.
Does anybody know if something like http://cgi.ebay.co.uk/UK-Infrared-48LED ... 455wt_1165 would work well?
Posted: Thu Mar 04, 2010 2:34 am
by coke
IR and color don't get along. If this things works as advertised, which seems fuzzy from their page, you're not going to get anywhere with it.
Cheap cameras are useful for a very limited set of operations.
